Question about Magic Mill DLX 2000 Stand Mixer
Magic mill just stopped working, but light is still on, so power still getting to machine
2 Suggested Answers
  • 549 Answers
SOURCE: magic mill mixer
You may be having a problem with the motor brushes and/or bearings.
Posted on Mar 04, 2008
  • 4 Answers
SOURCE: instruction manual for magic mill 2000
Posted on Sep 16, 2008
0 characters
1 Points
Proline 600
This is a fairly easy fix but you need a new planetary, some new grease a new gasket and about an hour. The planetary for your machine is a recent design, that did not work. the planetary and the shaft has been milled with grooves and they are pressed together at the factory. The tolerance was deemed to be tight enough to keep the shaft and the planetary together during the life of the machine....but sadly this became a common problem. They have since fixed the problem in the new design. They went back to pins and retaining clips from pre 2006. Your fix is inexpensive and ther are several videos on the internet showing you step by step how to do it yourself. Hope this helps.
Sep 17, 2014 | KitchenAid ProLine 600 Stand Mixer
Where can I download manual for the Magic Mill DLX2000 ?
The manual is $10 from the manufacturer, you can order from the following link.
Let me know if you need anything else.
Nov 04, 2010 | Magic Mill DLX 2000 Stand Mixer
Grain mill stops turning
Will it grind any wheat? I had a similar problem with the wheat overwelming the drive system and had to use smaller amounts of wheat to keep the system grinding. Do you have the feeder attached? I couldn't just load it up but had to feed a little at a time. Hope it helps. Favorable comments are apprieciated.
May 08, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Instruction manual for magic mill 2000
Jun 24, 2008 | Magic Mill DLX 2000 Stand Mixer
Dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
May 30, 2008 | Magic Mill DLX 2000 Stand Mixer
Magic mill mixer
Mar 04, 2008 | Magic Mill DLX 2000 Stand Mixer
Noise level
its possible that you got a lemon off the factory line or they forgot to put grease into the transmission there a warranty on it?if so take it back.i work for hobart which sold kitchen aid some years ago,if that mixer is less than a year old as stated,take it back or verbally speak to a kitchen aid rep. and tell them your situation.i really belive you should be able to get a replacement as long as you havent overloaded the unit or caused damage.let me know.
Jan 03, 2008 | Magic Mill DLX 2000 Stand Mixer
Magic mill DLX 2000 base sent to repair place
I just found my old invoice where I had sent my DLX to be repaired a few years ago. (I had not put in enough moisture and it walked off the (rickety) table I had set it on...)
I need to send it back again and hence my search for the info.
The gentleman I sent it to was Mordechai Roth at Magic Mill Corp in Monsey, NY (10952) This occurred back in 2000, I can't believe I saved the receipt...
Phone number is 914-368-2532 (If it's still good) I am calling tomorrow to see about sending mine in... Hope you find yours...
Nov 06, 2007 | Magic Mill DLX 2000 Stand Mixer
Magic Mill DLX 2000 Stand Mixer Logo
Top Magic Mill Food Mixers Experts
Custom Exchange
Custom Exchange
Colin Stickland
Colin Stickland
Are you a Magic Mill Food Mixer Expert? Answer questions, earn points and help others
