Question about Denon AVR-2700 Receiver
The left output is mutch less volume than the richt channel, while the inputs L + R are equal. Its on all inputs even the radio.
2 Suggested Answers
mlapres
  • 757 Answers
SOURCE: b&k avr 7 with SACD inputs needs independent tone equalization settings
For your stereo configuration, refer to the preamp they are connected to for tone controls.
For your center and surround channels, refer to the B&K setup menus for those controls.
Posted on Feb 04, 2012
Universal remote
ANYWHERE.. Walmart, bestbuy, dollar general, even dollar tree sells them.
Apr 07, 2016 | Clarion CX201 Radio / CD / MP3 player /...
I am not getting equal sound from right as I am on left. The right is a little less on volume and wattage meter,when I balance it fully to right and turn the volume up, the sound gets static and scrat
Check your connecting terminals on both ends for that channel that the polarity is correct and firmly connected. If you find no problem with that, then swap the connections...if the problem repeats to the other side then the speaker is damaged. If the problem stays on right side then it is the unit and needs to be investigated further.
Dec 22, 2014 | Pioneer Sx-1080 Monster Receiver Beautiful...
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
How to wire it to make the bass cuts off when offing the eq
This unit has a separate EQ band for the subwoofer-- you'd connect the sub-out from your CD player to the sub input on the EQ, and the sub-out from the EQ into the input on the sub amp.
The "sub" slider would then adjust the sub volume.
If your CD player doesn't have a sub-out, and you are just using one of the regular front/rear outputs to feed the sub amp, then the sub volume will follow the other sliders toward the left side of the unit, which is less desirable.
Feb 13, 2011 | BOSS AUDIO SYSTEMS AVA1204 7Band Car...
Mixer and an EQ & amp ?
The order is mixer, equalizer and amp. The output of the mixer connects to the input of the equalizer and the output of the equalizer connects to the input of the amp. The equalizer has three types of input and output connections. They are XLR, 1/4 inch and screw terminals. The mixer will have one or two of the three. Choose XLR if possible on the mixer, choose line level output on the mixer if possible. A XLR male to female cable is needed for the connection. The equalizer has two channels, if the mixer has two output channels the two output channels of the mixer can connect directly to the two input channels of the equalizer. If the amp has two input channels, the two output channels of the equalizer can connect directly to the two input channels of the amp. If the mixer only has one output channel then only one channel of the equalizer can be used and one channel of the amp likewise. A XLR male to female connection cable can be used to connect the equalizer to the amp.
Jun 23, 2010 | DBX 1215V Home Equalizer
Left channel faiure - no sound
If you have sound from one channel it is probably not a catastrophic failure of the output stages.
First isolate the problem. Does it occur with all inputs? If so, it is at a common stage after the input switch. Otherwise, it is before the input switch.
Do you have  anything patched into the signal path between the pre-amp and amplifier, such as a recorder or equalizer? If so, bypass it or remove it and see if that solves the problem.
Also, sometimes the metal contact surfaces in switches oxidize and collect contaminents, causing and interuption to the signal path. Make sure the volume isn't cranked, and then work the controls back and forth - if the channel comes back, even briefly, there's a good chance you can either clean it sufficiently by working the control or better, getting a can of contact cleaner from Radio Shack or the equivalent, removing the covers of the receiver (after pulling the plug), and spray the cleaner into each control before working the control back and forth a half-dozen times. With really bad controls, this can even cause the sound quality to improve.
If this doesn't isolate the problem, its time to take it to a qualified tech.
Nov 01, 2009 | Onkyo TX-DS656 Receiver
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
How to connect a sr430qx equalizer to abpm500 gemina mixer and a carvin dcm2000
All of three of these components have balanced connections. There are many different ways to connect- but this is the best option. You will need 4 x standard XLR3(cannon) mic leads. Starting from the Gemini mixer:
take the left output and plug it into channel 1(A) of the DOD EQ
take the right output and plug it into channel 2(B) of the DOD EQ
then...
Connect the EQ output of channel 1(A) to the input 1(A) of your Carvin amplifier
Connect the EQ output of channel 2(B) to the input of 2(B) of your Carvin Amplifier
Happy DJ'ing
Rus.
Feb 19, 2009 | Dual Audio Players & Recorders
NAD 302 stereo balance problem
I would replace the output transistors of the bad channel and any very low ohm resistors associated with them.
Whilst youre in there replace the electrolytic caps in the power amp section. Caps are cheap and plentiful.
I dont know what the rest of the circuit looks like but there might be a need to balance the DC offset after replacing transistors.
matelectronics.com and audiolabga.com carry many good replacement transistors.
Dec 30, 2008 | Audio Players & Recorders
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
