Question about Philips CDR770 CD Recorder
I NEED TO DOWNLOAD A USERS MANUAL FOR A PHILLIPS 770 CD RECORDER
I HAVE A 770 RECORDER BUT I DONT KNOW HOW TO CONNECT IT TO THE CASSETT PLAYER, CAN YOU HELP
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Philips Master
  • 102,366 Answers
You may download a copy of the manual here.
Posted on Feb 23, 2012
dunnbiker
  • 8546 Answers
SOURCE: im trying to records mix cd but isnt changing
• To switch off the Auto Track function you have to enter
Menu mode.
If you wish to increase track numbers manually, press
TRACK INCR(ement) on the remote control. For further
instructions see Menu mode.
ON (AUTO): The track increments are automatically taken over
from the digital source material or after 2.7
seconds silence during analog recording.
OFF (MANUAL): While recording track numbers can be
incremented manually by pressing TRACK
(Minimum track length is 4 sec.) (This can
also be done in Auto track ON mode.)
Posted on May 19, 2009
  • 1335 Answers
SOURCE: DON'T HAVE USER MANUEL
You can get a free manual from
http://audio.manualsonline.com/manuals/mfg/philips/cdr770_cdr771.html
Please rate this solution. Thanks.
Posted on Oct 13, 2009
SOURCE: my problem is my phillips cdr 770 wont accept
THE PHILLIPS CDR 770 WILL ONLY RECORD ON "MUSIC" CD'S.I USE A MEMOREX MUSIC CD FROM WAL-MART, IT'S A 40X700MB 80 MIN, IT WORKS FINE, HOPE THIS HELPS, GOD BLESS, PAUL
Sebin
  • 712 Answers
SOURCE: Phillips Model #FWC85C3701 radio, CD player,
The drive belt might have gone brittle and broken or might have loosened itself. You will have to replace it. You can do it by yourself if you have the replacement part. You can get a replacement, but searching for an online purchase over the internet is a great wastage of time. You can never find such items on net. Instead contact your nearest dealer or repairman. You may just ask him where to get the part and he will direct you to the right shop in your locality.
Cheers. Thank You.
Posted on Oct 23, 2010
technography
  • 6 Answers
SOURCE: Lost my manual for Phillips AZ8084 CD Radio
You can get a new copy (in PDF format) here.
Posted on Mar 10, 2011
CANT TRANSFER CASSETT TO CD
Hi Margaret,
You can download the manual for this device here. The downloaded file is called "ad-rw900.pdf" and should be found in your download directory.
Locate and open the file (Adobe Reader) and review page 31. Here you'll find the details to go about recording a CD from the source you've selected with the "Input Select" button. When recording to a CD-R or CD-RW with a cassette TAPE (or LINE IN or PHONO) as the source, you must manually set the recording level as directed in step 5 on page 32. Check the blank recording media. The device is ONLY capable of recording on "CD-R" and rewritable "CD-RW" blanks (these are very different from DVDs of any type). The CD-R type will likely enjoy wider compatibility (than CD-RW types) when played back on a different (car or other) CD player.
I hope this helps & good luck!
Dec 16, 2013 | Teac AD-RW900 CD Recorder and Auto Reverse...
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
Can I easily transfer data ie audio files from recorded music cassettes to the CD or USB with any of Sony cd/cassette player?
Cassettes don't contain 'files' or data.
The analog audio can be recorded to a CD.
For this specific model, it's all in the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RCD150-Boomboxes-manual/id/402ci674/t/2/
No usb on this one.
Feb 23, 2011 | RCA RCD150 Radio/Cassette/CD Boombox
My problem is my phillips cdr 770 wont accept the cds that i bought they are maxell 80 min normal cd r but the recorder saying wrong disc use audio cd so what cds do i use ????? am stumped it should use...
Sep 29, 2009 | Philips CDR770 CD Recorder
Im trying to records mix cd but isnt changing
Menu mode.
May 01, 2009 | Philips CDR770 CD Recorder
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
May 28, 2007 | TDK DA-3826 2-Disc CD Recorder
Philips CDR770 CD Recorder Logo
127 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
