What does the Lr code on my crosley washer mean and how can it be fixed
    Sergeant:
  • 316 Answers
SOURCE: What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Posted on Jan 14, 2009
TheRepairGur
  • 27 Answers
SOURCE: Neptune MAH55FLBWW front load washer LR code
LR = Locked (main motor) Rotor and very likely a new motor will be needed but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
TheRepairGuru --- www.RepairClinic.com
http://www.repairclinic.com/Maytag-Washing-Machine-Parts
Posted on Jan 27, 2009
milten1
  • 1304 Answers
SOURCE: code lr ?
hate to interject
but lr stands for locked rotor
your motor control has blown a fuse or heat sync.
you can verify this by removing the door and front panel,
the motor control is on the bottom right front
inspect this board with a flashlight
im almost sure you will find some sort of burning
if you do and would like to repair the unit im including a link
that will show you the part you will need
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47812
make sure you oder the part that comes with a new motor is actually cheaper AP4010145
Posted on Oct 18, 2009
  • 6 Answers
SOURCE: I have a maytag neptune
your machine has a fill problem either your screen is pluged on the water hose either hot or cold or your water is turned off.
Posted on Sep 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: what does the LR code on the neptune mean?
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Posted on Oct 01, 2010
I have a front loading machine(CAH4205AWJ) & it keeps giving me a Lr code.some times it fills with water and drains but never spins.
The LR code means "Locked Rotor". This could be due to:
  1. The control board at the top of the unit has lost connection to the motor and its control board at the bottom. Check for loose connectors. Also try 're-seating' each connector by pulling it off and pushing it on two or three times.
  2. The motor and/or control board at the bottom are shot.
Jun 18, 2014 | Crosley Washing Machines
What is Lr code mean.
Crosley digital front load washer error code lr
Does it beep or flash any other lights? What was the cycle or setting it was in when this appeared?
Aug 10, 2012 | Crosley CW5000 Front Load Washer
How do I fix the problem when the washer says Lr? Where do I start? Thanks!
If you take off the front panel and look closely inside there is a tech sheet with test procedures to follow. I will warn you the LR code is about the hardest one to figure out. It means locked rotor and its telling you that your motor is not turning. Good Luck.
Sep 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Crosley front load washer sometimes gives lr code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question &$^%^$T
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Mar 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
says:
Dec 21, 2008 | Maytag Neptune Washer
My neptune TL displays the code LR.
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
Dec 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
306 people viewed this question
Top Washing Machines Experts
