Question about Motorola Mobility HS850 Consumer Headset
Will not take charge
My headset is new just came in the mail the other day. I followed instructions as far as charging. It does not see to hold a charge. Have other motorola equipment so I use a different charger(same output) no go either. Help.
    Problem Solver:
  • 19 Answers
U might got a lemon. Since it's new, try to exchange it right away.
Posted on Aug 30, 2006
I m not able to connect my BH 208 headset to nokia E71 set
Make sure that the headset is properly charged before following the instructions below.Please follow the detailed instructions in the correct manner to successfully pair your Nokia E71 with the BH-208 Headset.
Charge the battery
The headset has an internal, non removable, rechargeable battery.Do not attempt to remove the battery from the device, as you may damage the device.
1. Connect the charger to a wall outlet.
2. Connect the charger cable to the charger connector. The red indicator light is on while charging.
It may take a while before charging
Switch the headset on or off
To switch on, press and hold the power key until the headset beeps and the green indicator light is displayed. To switch off, press and hold the power key until the headset beeps and the red indicator light is displayed briefly.
Pairing the headset
1. Ensure that your phone is switched on and the headset is switched off.
2. Press and hold the power key until the green indicator light starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the phone menu where you can view the currently paired Bluetooth devices.The headset is now ready for use.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex.
Jun 14, 2011 | Nokia BH-208 Wireless Headset
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
Not holding the charge
From the information you have provided, the battery in the unit needs to be replaced. From past experience, I can only suggest that you replace the H500 Headset. When I need a new headset, I've always been able to find one on eBay for a fraction of the retail price. (Usually about $20 for nice one in a 'bulk' package - where the same unit in a retail package would cost $89.95)
The ones I purchase on eBay are new, they just don't have a retail box or instructions (sometimes). If you elect to use eBay, and don't get instructions with your new headset - just re-post here on FixYa requesting a link to the owners guide and we'll send you one ASAP!
If you found this information helpful, please give me a big thumbs-up when you rare my answer. Thanks!
Feb 06, 2010 | Motorola Mobility H500 Wireless Headset
My new Cellular headset HFBLU-1K won't work or recharge
the problem seems to be the charging box. if the red light goes off relatively quickly after you place the bluetooth in the box then it is not gaining a charge. you have a warranty with this item that you can claim by following the instructions on the warranty card provided in the package.
Jan 29, 2010 | Cellular Innovations HFBLU-CX1 Wireless...
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Motorola Mobility HS850 Consumer Headset Logo
117 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
