Question about Ricoh Aficio 2035 Copier
Toner shooting out the end of toner cartridge
  • 227 Answers
The seal in the toner hopper is bad call you service people to have them replace it
Posted on Feb 23, 2012
New toner cartridge installed this printer but not accepted toner is ready but non dell toner cartridge error
BUY a new DELL cartridge . most mfg's have put chips on them that will not let the printer use a non OEM cartridge
Mar 08, 2016 | Dell 1600n All-In-One Laser Printer
HP1022N laserjet printer there are black specs along the printed page. looks like toner smudges.
toner specs are usually caused by a bad cartridge. If it is a refill, it is possible that the waste toner bin was not emptied when cartridge was refilled. Try different cartridge as your first trouble shooting step.
Jul 22, 2011 | HP LaserJet 1022 Printer
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
Keep getting a "toner end
If you are using a refilled toner cartridge or a third party cartridge that is most likely the problem.
Try using a factory new cartridge.
Don
Nov 11, 2010 | Office Equipment & Supplies
The toner light stays on even after we have replaced the cartridge with a new one. Recently we replaced the drum and it was working ok for a short while and then the toner light stays on and the printer...
Here you got bud just copy and paste all this **** below into the http:// window at the top of your web box:
http://docs.google.com/viewer?a=v&q=cache:uNJvw-MWncQJ:www.oasis-imaging.com/images/pdf/cart_inst/Brother%2520TN360.pdf+Brother+TN360+by+OASis&hl=en&gl=us&pid=bl&srcid=ADGEESj4M8XLUS4yMo7hAf3nTuGGvKtaYS5_tHhGdh9WoDGinffOkVJPv8cp642xaSG5PkbrNrcUssyMY1ggc1xYlSZEu-JNeY4iVcXWD9O7MKza5_7CjyQyTPW7nnZeAQWm_d7f-MEE&sig=AHIEtbTarYNPKakKRnVcXg3pW_PBoi_4tA
You gotta reset the plastic piece at the end. Also, get you some black electric tape and tape the 2 circular clear plastic plugs on each end of the cartridge. The sneaky bastards at Brother shoot a laser through these clear plastic plugs and when the toner goes below these plugs that causes your printer to say your out of toner even though your not. Therefore if you tape over these clear plugs, then you can squeeze another 225 pages of pure printing bliss without needing a replacement.
Nov 08, 2010 | Brother HL-2040 Laser Printer
SUPLY MEMORY ERROR
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the front right of the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector.
10.00.00 Troubles shooting Link GOHERE
Contact a local HP Authorized Service Center for further assistance.
Aug 17, 2010 | HP Hewlett Packard LaserJet P3005 Printer
Toner light is on on Brother HL-2170 Laser Printer and the computer is not recognizing a print task. Can you help me fix this problem? Also, I just replaced toner a couple weeks ago.
Description of Problem 100000013553
I just replaced the toner cartridge and the Toner LED is still on, or the status monitor continues to display the message "Toner Life End". What can I do?
Description of Solution 200000017394
@font-face { font-family: Verdana;}@page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; }P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"}LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"}DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"}A:link { COLOR: blue; TEXT-DECORATION: underline}SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline}A:visited { COLOR: purple; TEXT-DECORATION: underline}SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline}DIV.Section1 { page: Section1} If the Toner LED is still on, or the status monitor continues to display the message "Toner Life End" after installing a new toner cartridge, verify you are using a genuine Brother toner cartridge.
The yield of the TN starter toner cartridge is approx. 1,000 pages.
The yield of the TN330 toner cartridge is approx. 1,500 pages.
The yield of the TN360 toner cartridge is approx. 2,600 pages.
Approximate cartridge yield is declared in accordance with ISO/IEC 19752(Letter/A4).
Brother strongly recommends that customers use only genuine Brother drum units and/or toner cartridges. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of third party drum units, toner cartridges or toner.
1. Verify you installed a NEW, out of the box, genuine Brother toner cartridge (TN360/TN330).
If a toner cartridge from another machine was installed (even if there?s still toner left in the used cartridge) or a starter toner cartridge (included with the purchase of a machine) was installed, the Toner LED will stay on and the message "Toner Life End" would continue to appear on the display.
2. Verify the toner cartridge is installed correctly by following the steps listed below:
a. Open the front cover by pulling the tabs on the left and right side of the printer towards you.
b. Lift the drum unit slightly and pull it out. Place the drum unit on a piece of disposable paper or cloth to avoid spilling and scattering the toner.
c. Remove the toner cartridge from the drum by holding down the lock lever (blue tab) on the left side of the drum unit and lift the toner out. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wash it off with cold water.
d. Gently rock the toner cartridge from side to side five or six times to distribute the toner evenly inside the cartridge.
e. Place the toner cartridge into the drum (be sure it clicks into place).
f. Clean the primary corona wire inside the drum unit by gently sliding the blue tab on the top of the cartridge from right to left several times. Return the blue tab to the home position before reinstalling the drum unit assembly.
g. Reseat the drum unit into the printer pressing it in securely.
h. Close the front cover making sure it latches on both sides.
If the Toner LED is still on or the status monitor continues to display the message "Toner Life End" the printer will need service.
The printer has a one year limited exchange warranty. If the printer is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the printer is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
Jul 21, 2010 | Brother HL-2170W Laser Printer
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
End of toner life on Brother HL-2140
What you should do is look at the short sides of the toner. You will notice a clear round piece with tabs sticking up. What you need to do is color the inner part of the circle with a sharpie. This should give you another 100 prints or so. After you've exhausted that option, cover the spot a few times with electrical tape. What this is doing is block the "low toner" laser from shooting through these open spaces, tricking it into thinking it is full. Be sure to be observant; when the paper begins to look 'dirty' it is REALLY time to replace the cartridge. I've gotten up to 2,000 prints extra by doing this!! Good luck!
May 13, 2010 | Brother HL-2040 Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Ricoh Aficio 2035 Copier Logo
29 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
