Question about Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump
I have a Craftsman (919.176820) 2HP, 12 gal. compressor. I starts fine the first time, it reaches full pressure and cuts off. When the pressure drops and it tries to start again, the motor lugs and trips the breaker. Do I have a motor or compressor problem?
  • Craftsman Master
  • 885 Answers
Your tank check valve is stuck/broke. It's on the tank end of the line from the pump to the tank. It is supposed to close when the pump stops to keep air in the tank and let the system bleed pressure out of the pump so the motor can start when there is pressure in the tank. The part you need is CAC-437-2 and is available through searspartsdirect.com.
Posted on Feb 23, 2012
  • 89 Answers
SOURCE: compessor trips circuit
IT SOUNDS LIKE YOUR COMPRESSOR IS NOT UNLOADING WHEN IT SHUTS DOWN. YOU SHOULD HEAR AN AIR RELIEF SOUND TYPICALLY ON THE SIDE OF THE PRESSURE SWITCH WHEN IT SHUTS DOWN. ITS A SMALL VALVE WITH A TIRE VALVE THAT THE LEVER HITS AND RELIEVES THE PRESSURE FROM THE DISCHARGE LINE AND THE TOP OF THE PISTON.
YOUR CHECK VALVE COULD BE BAD LETTING PRESSURE BACK UP BUT IT WOULD BE BLOWING AIR OUT ALL THE TIME WHEN SHUT DOWN.
IF YOU THINK THE VALVE OR SWITCH IS WORKING AND WANT TO CHECK IT, LET THE COMPRESSOR BUILD UP AND SHUT DOWN, LISTEN FOR THE AIR RELIEF,IF IT DOESNT THEN CRACK THE DISCHARGE LINE AND SEE IF THERES ANY PRESSURE, MANUALLY RELIEVE THE PRESSURE THEN USE SOME AIR AND SEE WHAT HAPPENS. REPAIR VALVE ON THE SIDE OR CHANGE PRESSURE SWITCH $30-40.00. HOPE THIS HELPS. PLEASE REPLY. JODY
Posted on Apr 05, 2009
  • 104 Answers
SOURCE: lack of pressure
the pressure switch needs adjusting - need service book for that one - but I do not think the pressure switch is servicable- I think you have to have switch replaced at service centre.good luck
Posted on Oct 26, 2008
  • 68 Answers
SOURCE: I have a craftsman 3.5HP 30 Gal compressor (Model
Unless your machine is worn out----it's probably the pressure switch:
A: needs adjustment
B: needs to be replaced
XYZ: head gasket leak,broken line, other air leaks?
Posted on Apr 25, 2009
roniecon
  • 6826 Answers
SOURCE: hi just found this site trying to remedy a
look at he check valve
Posted on Jul 06, 2009
  • 5603 Answers
SOURCE: My craftsman air compressor model 919 16737 1.1 hp
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
Posted on Aug 24, 2009
My compressor does not reach more than 30 psi on tank pressures why ?
hi there,
there are certain reason,try to adjust your pressure switch to as certain pressure you want,doing this refers to service manual on adjusting cut out and cut in pressure.there is adjusting screw on a box, mounted on the compressor tank.another factor for not reaching the set up pressure is lost compression observe on this is, a mechanical malfunction of worn out piston ring.if this a reason replace piston ring this should be done by certified
mechnic.have a nice day dont gorget to fix my rate,thanks a lot.
May 06, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I HAVE A CRAFTSMAN 1 HP 12 GAL AIR COMPRESSOR THAT WILL ONLY BUILD 20 PSI THE COMPRESSOR ONLY HAS 1.5 HRS RUN TIME ANY SUGESTIONS
hi there, if the compressor built up a 20 psig and run at 1.5 hrs.then stop.check the pressure switch the differential pressure cut in and cut out limit.adjust the cut out to the corresponding cut out pressure you want but not exceed to the designed pressure tank..this will be done on adjusting cut out pressure screw mounted inside the pressure switch.follow the instruction on the manuals adjusting pressure switch.the run time correspond to the cut out limit of the pressure switch. rate my fix if your satisfied thank a lot.
Apr 20, 2010 | Air Tools & Compressors
Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Apr 05, 2010 | Air Tools & Compressors
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I started it but when it got up to max 120 it cut off. What should i check? Or do you know where I can get a manual?
Unless I am mistaken, all compressors, with the exception of continuous run, cut off when they reach a pre set max pressure
Jul 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Porter cable compressor will not restart once it is under pressur
This is likely a bad check valve which is allowing pressure from the tank to leak thru back to the compressor. The compressor won't start because the compressor cylinder has air pressure on it.
The check valve is about the size and shape of a .410 shotgun shell -- it's in the copper line from the compressor to the tank.
May 27, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Press. switch won't shut off motor when reaching cut-out pressure
IF THE SWITCH WILL NOT SHUT IT DOWN ITS NOT WIRED CORRECTLY, THE POINTS IN THE SWITCH ARE WELDED TOGETHER AND WONT RELEASE OR THE LINE UNDER THE SWITCH IS CLOGGED
Apr 03, 2009 | Craftsman Air Tools & Compressors
Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump Logo
455 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
