When I turn it on I do not see anything in my monitor only it only does a beep sound
  • 108 Answers
There are beep codes that tell you problems.
No video with beeps means that there is no memory or bad memory on the motherboard, also -
No video with beeps means that there is no working video adapter on the motherboard.
No video with beeps means that there is no working processor on the motherboard.
I recommend re-seated the ram and the video card, if there is one.
Hope this helps
G'luck
Posted on Oct 27, 2008
Dose the server beep sound no display
If you only hear beep sounds but no display on your monitor it might mean a los of different issues.
Chech if your monitor works, connect it to another computer. If it woeks count how many beep sounds do you hear when you turn on your computer., go to google and input "meaning of beep sounds" Depending on numbre of beeps, you can get a fast diagnosis. Probably you have ahardware issue. If it is not tne monitor, it is your server and I suggest you should take it to a reapir shop
Sep 21, 2014 | Computers & Internet
Beeping sound when starting
Usually when you first turn the power on ... it's usual to hear a couple of beeping sounds . And then, you may hear whirling/clicking sounds when your disk starts up (rotating) and your CD/DVD drive starts up, etc.. Then the monitor/screen lights up and starts to show the operating system (e.g. Windows) panel ... as it starts up.
If your system just beeps ... and beeps ... and beeps... and nothing else happens, the screen doesn't light up and show anything (for a few minutes), it likely the system is not starting up properly.
If you can clarify what actually happens, maybe I can offer more suggestions/information to help.
Apr 03, 2014 | Computers & Internet
Hp pavilion a1220n comptur will not start unplugged unit and when i plugged to back in it would not start
Do you see anything on the monitor screen? Does the tower make any beeping noise or clicking noise, or does the fan tries to start up when you power the computer on? Are the cables connected properly?
If you see anything on the monitor screen, or if you hear a beeping sound, let us know so we can diagnose further.
Aug 07, 2011 | HP Pavilion a1220n (A1220NED904AA) PC...
My computer turns on and starts makeing a beeping sound. and the monitor wont show anything. how do i fix this
You have to find out what the beep codes mean, try checking out the PC manufactures web site, follow links for support.
Dec 02, 2010 | Computers & Internet
The computer does not fully boot when turned on, and the tower makes a continuous beeping sound. The monitor works fine, the problem is the tower. The tower just keeps on beeping without turning on or...
Hello
That beep could mean alot of things, but probably a VIDEO CARD or RAM has become unseated.
If you feel comfortable with this, UNPLUG THE COMPUTER take off the case, remove and reinsert the ram chips, and the cards. You might need a screwdriver or two, and a LIGHT. The ram tabs are small.
Good Luck
Nov 25, 2010 | Microsoft Computers & Internet
When I turn on my monitor, its goes straight to a
  • when you turn on computer. after sometime your monitor goes to standby mode and monitor light colour will be orange it means problem with your computer not monitor.
  • After this You Check your VGA Card.
  • When you turn on computer is there any beep.
  • After this also check your RAM.
  • May be problem with your RAM.
Try this Technique .
Mar 13, 2010 | HP w1907 LCD Monitor
No beep, no display, cant find the problem... help!!
I am thinking it's either a bad board or it's the power supply. I would try to hook it up on someone elses monitor in order to check and make sure it's not yours. If it doesn't work then I would go get the board tested by a pc tech or buy another.
Dec 27, 2009 | ASUS Computers & Internet
Continous Beeping sound
Hi neosw,
Could you provide a little more detail?
Was this a previously working set-up or is this a new build?
If this was a previously working set-up have you changed anything?
When you switch on the PC
  • do you see anything on the screen, does the monitor remain in standby?
  • are any of the fans running?
  • does the hard drive spin up?
  • does the beeping sound stop after a short while?
The reason I ask these questions is because a continues beeping usually means that the BIOS is not seeing the processor, or that the power to the processor is not correct. With some BIOS manufactures it can also mean the processor clock speed is not set
correctly.
Please don't take this the wrong way but...if you provide greater detail in your question, the easier it for us to diagnose your problem, otherwise we can only make educated guesses.
I hope this has been of some help.
Regards,
Spare head 2
Jan 06, 2008 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
Laptop does not start; long beep heard, no display
Have you attached an external monitor prior to turning it on?
Also, does it power up with battery and ac adapter? Try taking the battery out, and also just using memory in 1 slot.
Let me know
Good luck
Oct 06, 2007 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
