Question about HP PhotoSmart 1215 InkJet Printer
Hp 1215 problem after paper jam
I had a paper jam. Removed paper through back. Eerror lights stayed on and carriage just runs rapidly from side to side and makes teribble banging noise. Cannot see any obstruction. Phoned telephone assistance line and they said turn off. turn back on. Hold down ON and PAPER SIZE buttons. When released same problem persists. Cannot print at all now. Thank you. Regards Roberta
  • Billingdad Nov 17, 2007
    My prolem is exactly as drumgirl's I have done the same thing to try and solve the problem but the orange lights are showing 1) check paper 2) check printer cartridges. When I try and print a document the error message comes onto my screen "Mechanism Error" "The print cartridge cradle cannot move." The printer cartridge cradle is moving freely and occasionally moves from side to side but a clunking sound is heard when the cartridge is seated to the rignt. If I open the front flap as if to replace the cartridge the cradle does not move at all.... I have just replaced both the printer cartridges at a cost of £50.00 and I am reluctant to throw away the printer.. please help if you can. :(
    Master:
  • HP Master
  • 459 Answers
Step 1: Remove any loose paper first
Step 2: Clear the jam from the output tray
-> With both hands, grasp the jammed paper where it is most visible, including the middle, and then carefully pull the paper straight out of the output tray.
-> Open and then close the rear door to clear the error light.
Step 3: Clear the jam from tray 1 area
-> Raise the jam access door, and then pull out tray 1.
-> Check inside the product for jammed paper. With both hands, grasp the jammed paper where it is most visible, including the middle, and then carefully pull the paper straight out of the product.
-> Reinstall tray 1, and then lower the jam access door.
-> Press the Resume button to continue printing.
Step 4: Clear the jam from the fuser
-> Open the rear door.
-> With both hands, grasp the jammed paper where it is most visible, including the middle, and then carefully pull the paper straight out of the fuser area.
-> Close the rear door.
Step 5: Reset the printer
-> Press the Power switch to turn off the product.
-> Wait 30 seconds and then press the Power switch to turn on the product.
Step 6: Reload paper and try printing
-> Pull out tray 1.
-> Slide the paper length and width guides to their outermost positions.
-> Tap a stack of plain, white paper on a flat surface to align the edges.
-> Load the paper into tray 1 and make sure that it is flat at all four corners.
-> Slide the paper length and width guides inward until they stop at the edges of the paper.
-> Push the paper stack down to make sure that it is below the paper limit tabs on the side of the tray.
-> Slide tray 1 into the product.
Step 7: Check print settings
-> From the File menu in the software program, click Print.
-> In the Print dialog box, click Properties.
-> Check the settings on the Paper/Quality tab, change them if necessary, and then click OK.
-> Try printing again.
If these steps resolved the issue, there is no need to continue troubleshooting.
If the issue persists, see the next step.
Step 8: Clean the cartridge area
-> Open Toolbox.
-> Windows XP: Click Start, click All Programs, click HP, click your product, and then click Toolbox.
-> Windows Vista: Click the Windows icon, click All Programs, click HP, click your product, and then click Toolbox.
-> Click Help and then click the Troubleshooting.-> In the Cleaning Mode area, click Start to begin the cleaning process.
-> The product processes a single page, and then returns to the Ready state when the cleaning process ends.
Step 9: Service the printer
Call Our (Toll-Free) 1-888-224-4280
Posted on Aug 31, 2018
geemarie
  • 876 Answers
SOURCE: HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
Posted on Aug 15, 2008
SOURCE: hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Posted on Nov 09, 2008
  • 72 Answers
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Posted on Jul 22, 2009
male_28_cam
  • 1555 Answers
SOURCE: Won't print. Message says
It is giving carriage jam not a paper jam the carriage is the part which carries cartridges on it. It seems your carriage is jam and can't move left and right so open the door and try to move your carriage with the help of rubber roller which moves your printer. Also clean the steel road on which the carriage moves just check at the corner of cartridge carriage if any paper bit is stuck or excessive paper dust has jammed it. If this does not solves your problem kindly comment back.
Posted on Jul 28, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: carriage stall.. clear carriage obstruction and press resume...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Jul 27, 2010
C5180 jam in carriage - removed paper but not printing
Check at the cartridge end of the machine. I found a piece of paper jambed in that kept the carrige from parking on the right side. I had to turn off printer. take the paper trqy out and turn the machine on it's right side and use a flashlight to find it and get it out.
Dec 31, 2014 | HP PhotoSmart Office Equipment & Supplies
Ink cartridge jam
Try cleaning the carriage bar. This is a shiny rod that the ink carriage slides back and forth on. Wipe it off with a clean rag and put a drop or two of light oil on the rod. The carriage should move easily back and forth.
May 01, 2017 | HP Photosmart C5280 InkJet Printer
Info printer :E
Any malfunctions its gives error 'E'... Check paper jam, carriage struck, cartridges faulty and service related issues.checking carriage:Switch on the machine check carriage(the unit carrying print heads)moving left & right.. if its not moving, it might be struck in service station(service station located at right end and its allow carriage to rest on it during shut down as well as its cleans the print head nozzles). power the machine pull carriage out gently, don't force it..Clean encoder strip: Encoder is located back side of the carriage and its guides carriage to move properly, if encoder became dirty you will get error message, clean encoder with smooth cotton cloth.
Feb 03, 2012 | HP PSC 1215 All-In-One InkJet Printer
Paper jam light on permanently, printer is jammed
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
Nov 18, 2010 | Office Equipment & Supplies
Hp 6940 printer has flashing resume and power light, no paper jam and carriage seems to move ok....
Check the Encoder Strip (metallic) that runs the length of the printer in the back of the carriage. If it is loose the carriage will not line up correctly in the printer and cause the lights to flash. On the inside right of the printer behind where the carriage sets when you change the ink look to see if the metallic encoder strip has come off the hook. If so simply reattach it to the little metal hook and the printer should start working again.
Sep 14, 2010 | HP Deskjet 6940 InkJet Printer
How do I re-set after a paper jam hp psc 1200?
Verify that the print cartridge door is closed.
The print carriage may be jammed, follow these steps to correct the problem:
1.
Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
2.
Disconnect the power cord from the all-in-one.
3.
Remove both print cartridges.
4.
Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
5.
Close the print cartridge access door.
6.
Plug the power cord back in.
7.
After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
8.
Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
If that doesn't work, maybe try this too:
Clearing paper jams
Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
1.
Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
2.
Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you.
NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems.
Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
If under warranty, contact HP to obtain a replacement part.
Click How to buy on this page to order replacement parts.
3.
From the rear access door opening, gently pull the jammed paper free.
4.
Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
5.
Reattach the rear access door by inserting the two pins on the right of the door into the holes for them and then pressing in gently but firmly on the left side.
6.
Reconnect the power cord to the unit and turn the unit on. Source(s): http://www.castleink.com
Sep 01, 2010 | Computers & Internet
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
Hp photosmart carriage jammed
I had the same problem and finally solved it this way. After hours of trying to find out where this carriage was, to no avail, I finally decided to move the printer head by hand, which was way over on the right side and I found out it is also the carriage. I unplugged the printer and slid the carriage all of the way to the left, looked back in there using a flashlight and low and behold there was a wad of paper, it took some doing to get it out. What fooled me was that when the message came up i took the back off and there was two 4x6 pieces of photo paper jammed in back, I removed them and thinking that's all there were, I never thought to look for any more paper.
Hope this helps
Dec 26, 2008 | HP Photosmart 3210 Printer
HP PhotoSmart 1215 InkJet Printer Logo
246 people viewed this question
Clive
Clive
