Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
I have a john deere 6810. The parking lock will not hold the tractor stationary when under load. I have not been using the handbrake as it does not work. My question is should the parking lock be used as a handbrake and if so what would cause it to fail under load.
    Sergeant:
  • 316 Answers
Hello, parking brake adjustment,,if you look under the tractor behind the right wheel next to the trans. you will see a round disk with a small shoe,turn that in to adjust brake,hope this helps,,
Posted on Feb 23, 2012
SOURCE: JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Posted on Oct 09, 2011
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
wireguy212
  • 1627 Answers
SOURCE: error code 74 on john deere 3320 tractor
Lcd display switch is stuck in the on position either play with the switch until the code goes away or have the dealer replace the switch,it should still have warrenty.
Posted on Dec 02, 2009
My john deere 3038 will not allow a parked exhaust filter cleaning
Needs to be moving and with a load to keep the engine warm and at operating temperature for at least 20 minutes. And full throttle..
Sep 25, 2016 | John Deere Garden
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
Nov 15, 2015 | John Deere Garden
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/...J7/Output/OMLVU17926_J716.html
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM139226.../OMM139226_A99.html
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
How to lock brakes when parking jd 401 tractor
I find this forum helpful for equipment questions:
John Deere 401C TLB Questions
Jan 02, 2015 | Garden
The parking brake on my John Deere L118 is stuck in the activated position. Therefore the tractor won't roll. How can I disengage the parking brake?
Usually there is a red handle under the steering colunm that locks the pedal down. You will need to depress the brake as you push down on the red handle which should release it.
Oct 11, 2009 | Garden
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
388 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
