Question about Car Audio & Video
I have a 2005 chrysler town and country. The rear entertainment system plays, but there is no sound. Any ideals.
  • 137 Answers
SOURCE: 2005 town and country
when the blower resistor burns out the blower motor will not work sometimes on only one or more speeds its located in the heater box on the passenger side. its held in with 2 fasteners the part is inexpensive.
Posted on Jan 11, 2009
chryslertech
  • 115 Answers
SOURCE: low speed fan relay for the 2005 chrysler town and country
If you are talking about the cooling fan relay for the radiator there is no low speed and high speed relay. There is only one relay and it is behind the grill revitted to the bumper rail. It is doesnt look like you typical relay.
Posted on Mar 08, 2009
alicantecoli
  • 22156 Answers
SOURCE: Chrysler trouble code U110C on 2005 chrysler town
encrypted software ,dealer only----yes i know you are showing a reading but it doesnt mean anything or if it does it shows a different code .so your snap on or mac tools scanner is a waste of time and money.Nearly all new motors from 2005 are using encrypted software to stop general mechanics like me from working
Posted on Sep 12, 2009
  • 79 Answers
SOURCE: power door locks on 2005 chrysler town and
There is an ecu flash for this repair. You may get the locks to start working again with a battery disconnect.
Posted on Jun 18, 2010
  • 17 Answers
SOURCE: 2005 Chrysler Town & Country. Passenger side window problem.
HAVEK 1005 sounds right on track.... but also try this, usually works well for non functional power windows, specially Caravans.
NO COST PROCEDURE TO FIX IT:
1. Sit in vehicle, on seat next to problematic window
2. Ignition key is on
3. Door in question is opened (in case you closed it)
4. While door is open, press and hold power window button in desired window travel, keep button pressed !!
5. SLAM hard the door closed with one hand while other hand holds button as per #4.
6. Watch window operate as it should.
7. Repeat 3-6 if necessary, but usually the first try works!
NOW, for the naysayers that says you must replace power window motors etc, at $$$ cost because the above fix does not work, or is not long lasting fix, or less than a "professional fix".... Well then, when the window fails to operate again, apply same fix again at that time.
I have fixed my van this way numerous times (usually once a year), and to all local friends I recommend this fix too, likewise do the same and are happy with the solution.
Posted on Jul 17, 2010
How do I test the A/C low pressure switch on a 2005 chrysler town and country
use the appropiate machine to empty the gas from system then check the switch then refill and check again should be the opposite function although i suspect lack of gas by weight as this will stop the pump from coming on .All modern R134 AC systems are extremely dangerous to diagnose and play around with and can result in serious injury so i strongly suggest you take vehicle to certified technician
Sep 22, 2012 | 2005 Chrysler Town & Country
Rear brake lights not working 2005 chrysler town and country
check fuses but first refer to owners manual to see proper disconnection of battery neg. first -- obtain acess to brake lights and use dvom ''digital volt ohm meter '' to test continuity to brake lights
Dec 15, 2011 | 2005 Chrysler Town & Country
2005 Chrysler Town and Country Touring rear defroster light comes on but no power to rear defroster
If there is no power at either connector on the window the first place I would look is the harness that goes in between the hatch and the body. It is pretty common for the wires to break in that area.
Nov 11, 2010 | 2005 Chrysler Town & Country
Leaking green fluid from right rear near tire of a 2005 town and country. What is it?
most likely coolant (anitfreeze) if it has rear heat pressure test system to find leak hose,clamp,etc...
May 02, 2010 | 2005 Chrysler Town & Country
Chrysler Town & Country Minivan Rear Drum Brakes
I replaced the brake pads on a '94 Chrysler town and country, I had the rotors turned also, I did not use any anti-vibration substance on the shoes. I hear a clicking noise from front brakes.
Apr 16, 2010 | 2005 Chrysler Town & Country
Does my 2005 Chrysler Town and Country have rear disk brakes?
look under rear of vehicle at rear tires or it can see thru opening in rim look and see if they look like the front
Oct 28, 2009 | 2005 Chrysler Town & Country
My 2005 chrysler town and country is making a noise underneth the body
most likely the rubber grommets in the suspension i just had mime replace in my 2005 chrysler t&c same for my brother in-law on his caravan. it sounded like a shock was broken. it cost me 85 my brother in-law 110
Aug 29, 2009 | 2005 Chrysler Town & Country
Front vents will not work
If they are stuck on defrost,then the problem is a little vaccum line that comes through the firewall as all the climate controls are vaccum controlled,so look for a small green or black plastic line unhooked.
Dec 25, 2008 | 2005 Chrysler Town & Country
Heater putting out cool air.
i need a diagram to replace the rear pads i can't take off the caliper on 2005 chrysler town & country
Dec 16, 2008 | 2005 Chrysler Town & Country
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
