Question about Gund Sesame Street: Elmo 25" Plush Doll by
Let's rock elmo
  • irishtinknd
    irishtinknd Feb 22, 2012
    ///let's Rock Elmo won't finish singing the songs and his arms no longer move. I've changed the batteries, but it didn't help.
Where I can find a service manual and maintenance for a projector Elmo FP-C?
I "Googled" the projector name & found service documents for it at: www.photobooksonline.com I hope this helps!! Jim
Feb 18, 2013 | Office Equipment & Supplies
Camera does not work
If it's just a blank screen than you may need to charge it or buy a new battery all together. It's hard to say when you don't specify the kind of camera.
Aug 20, 2012 | Elmo Projectors ELMO TT02RX DIGITAL...
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
My Elmo TT-02RX document camera is not working properly. The blue power light does not stop flashing when I turn it on, and I am unable to use the camera or switch over to projecting what is on my...
Your Elmo TT-02rx comes with a five year manufacturers warranty. Contact Elmo at 1-800-947-ELMO and they will instruct you as to how to trouble shoot your doc camera or send it in for warranty service.
Apr 14, 2011 | Elmo Projectors ELMO TT02RX DIGITAL...
The camera head on the Elmo document camera will not stand up. Keeps falling.
Your doc camera has a 5-year manufacturer's warranty. Elmo has a great warranty department and will repair your product quickly.
You can download a warranty claim form which will have instructions as to how to submit your product:
http://www.elmousa.com/files/service.pdf
Mar 11, 2011 | Elmo Projectors Elmo TT02RX Document...
Zoom dial is broken teacher overturned it
don't have a solution but I have two Elmos tt-02s with the same problem
Feb 11, 2011 | Elmo Projectors Tt-02s Slide Projector
Hokey Pokey Elmo sings and moves his hand and foot but stopped shaking and won't turn around in a circle. It worked fine then stopped working we changed the batteries and it worked a short time then quit...
Hi ms_debbie13
    How to Activate
  1. This plush, shiny red Elmo is standing with his arms up above his head. One foot is lifted slightly off the floor and the other is on the floor. On that foot, there is a swivel allowing Elmo to turn, the battery door and the on/off switch. Turn Elmo on and stand him upright then squeeze his left hand to begin his song.
    Elmo really moves his right arm and leg in time with the song, and also turns in a circle. When the song is done Elmo says, "Whew.. that was fun! Elmo's pooped!"
  2. Alternative Mode
  3. The alternative mode is Elmo trying to keep up as the music keeps getting faster. If Elmo falls over he will say, "Woops!" and then he will thank you when you set him back upright.
Jan 30, 2011 | Toys
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
Need to upgrade video camera in an Elmo TRV-s8
Not sure if that can be done but give Elmo Service a call. www.elmousa.com
Feb 23, 2010 | Elmo Projectors TRV-35H Slide Projector
Forgot how to use it!
Try Elmo's website. Google Elmo TRV-35 H. A PDF of the user manual is available free for download.
Apr 07, 2009 | Elmo Projectors TRV-35H Slide Projector
Gund Sesame Street: Elmo 25" Plush Doll by Logo
420 people viewed this question
Top Gund Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gund Toy Expert? Answer questions, earn points and help others
