Question about Lanier 1205 Copier
Power no power code sc 552
  • 42 Answers
Presure roller warm-up error.
Posted on Dec 11, 2008
Ricoh 2018D error code sc 552
Do following steps
1. Yellow cancel
2. 107
3. Hold down red clear/cancel
Machine will beep.
Select 1 - copier sp
Type 5# 810# (fuser sc reset)
Select execute and restart the machine.
If code re-appears you have a faulty fuser lamp or thermostat.
If machine works for a while or at least tries to warm up, you have a faulty thermistor.
Feb 06, 2018 | Ricoh Office Equipment & Supplies
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh photocopy functional problem SC 552
Sc 552 is Heating roller warm-up error 2
• The heating roller temperature does not reach the ready temperature for 90 seconds after the heating lamp on.
• The heating roller temperature does not reach 80°C for 13 seconds after the IH inverter on.
• Defective thermistor
• Defective IH inverter
to solve that problem u have 2 solutions
1. Check if the heating roller thermistor is firmly connected.
2. Replace the IH inverter.
Dec 16, 2017 | Ricoh Office Equipment & Supplies
What is sp mode
sp is sleeping mode.in these mode the printer`s engine code works best thats why when clearing codes as technicians we prefer machines to be in sp mode that is
Oct 26, 2016 | Ricoh Office Equipment & Supplies
What is sc 552 error code on a MP6002SP
Dirty fusing thermistor. Clean it, go into tech mode and turn off main power switch to reset it.
Aug 29, 2014 | Ricoh Office Equipment & Supplies
I HAVE A PROBLEM(errore sc-552) WITH MY COPIER Ricoh Aficio 2027 All-In-One Laser Printer
found this solution on line -Ricoh Copier Error Code SC 552 is Fusing thermistor error 2 problem
1. Fusing lamp is not connected angry.gif:(" title="Angry"> (reconnect it)
2. bent or is bad [img src="http://copierliquidationcenter.com/Copier_University/Smileys/default/angry.gif" alt=">:(" title="Angry"> (replace it)
3. Thermistor position incorrect [img src="http://copierliquidationcenter.com/Copier_University/Smileys/default/angry.gif" alt=">:(" title="Angry">
Try to reset this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
.... if this is not working, you might need new Fuser Thermistor ... go to Copier Parts Outlet.com find your copier, order your copier thermistor .... they have YouTube videos how to replace them too ...
Try this Video first:
youtube.com/watch?v=2S_jH3MOwr4
Jan 14, 2014 | Computers & Internet
Codigo sc 552 ricoh 3800
SC 552 - Pressure roller warm-up error
Definition: After the main switch is turned
on or the door is closed, the
pressure roller temperature
temperature within 150
seconds during fusing unit
warm-up.
Possible Cause:
• Pressure roller fusing lamp broken
• Defective pressure roller thermistor
• Defective BCU
Troubleshooting Procedure:
1. Check if the pressure roller thermistor
2. Replace the fusing unit.
3. Replace the BCU.
Mar 01, 2011 | Ricoh Aficio 3800CMF Laser Printer
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Good luck and please rate me, thanks.
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
102 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
