Question about Refrigerators
My GE SXS TFX22CRXD WORKING GREAT BUT,COMPRESSOR SEEMS TO BE RUNNING TO OFTEN
I THINK SEALS ARE OK. BOX HOLDING GOOD TEMPS. COMPRESSOR IS NOT SHORT CYCLING,BUT RUNS OFTEN. IM STARTING TO WONDER IF DEFROST ELIMENTS ARE STUCK ON
  • 262 Answers
SOURCE: Clicking noise from compressor and fan runs 24/7
check the grounds to the ref. also check power to the ref. but it sounds like you have a floating ground the only thing else to mke comp.cycle is the relay which is on the comp. itself
Posted on Jan 08, 2008
  • 5 Answers
SOURCE: GE sxs defrost problem
replace the thermister on the evaporater and check to make sure ice dispensor door is closine properly
Posted on May 16, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire Model number frs26znh defrost not working?
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Jul 25, 2008
SOURCE: how do I force a defrost on a ge sxs gss20iepcww
on all ge electronic models produced since 2000 the main power lead to the main board can be jumped to test either defrost or compressor operation.to do this unplug the unit and locate the 3 wire plug (usually blue in color) .unplug the harness from the board and create a jumper wire to by pass the board.the terminals on the board will be identified as line,compressor and heater.to put unit in defrost install jumper between line and htr or def .this will ck the defrost sys.once unit is plugged in with jumper in place the heater will come on.if the heater does not come on look for a defective heater or defrost t/stat.hope this helps.
Posted on Jun 04, 2009
  • 10865 Answers
SOURCE: ge profile artica not cooling
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Posted on Aug 16, 2009
    GE TFX22P Refrigerator Evaporator Fan
    Fun run as long as the compressor runs and you do not need to worry about it. the only thing you need to verify are the temperatures in the refrigerator and and freezer compartment: below 40-F, and below 0-F
    if temp ok, do not wory about it.
    Aug 18, 2014 | GE Profile 21.6 cu. ft. Side-by-Side...
    My GE Artica fridge seems to be freezing then defrosting then freezing again. All of the carboard boxed food is caked with ice and the boxes deterioriate and I have tried resetting the freezer temp s
    Those refrigerators have a lot of issues so if you can return it I would. But you can check to see if the freezer fan and fan by the compressor are working. They should be running whenever the compressor is running. If they are you'll need a technician to check out the rest.
    Nov 12, 2011 | GE Profile Arctica 25.4 Cubic Feet...
    I have a GE bottom freezer model TDC18PAAWW. It seems to be working fine but has begun to produce a clunking noise when the compressor starts and stops. Do you have any idea how serious this is and what...
    just keep an eye on your fridge temps over the next few weeks if there ok then its just getting noisy with age but if it doesnt hold its temp then the compressor is on its way out but the compressors very rarely fail i would say its just getting older & noisy.
    Jan 12, 2011 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
    Freezer temperate has dropped to -8 but is still working and making ice cubes. food is not solidly frozen. fridge temperature is 3 and ok. repair man could not find anything obviously wrong but said the...
    yes the compressor seems to be good but it has an internal overload inside the compressor if that collaps your compressor is busted but try to ajust the temp..or reduse the refrigerant charge to minimal the running hour of the compressor.
    Aug 11, 2010 | GE Freezers
    Just quit working everything seem to be fine, checked continuity on compressor, o.k., but can't hear it start, and the lines to and from seem room temp.
    The first place to start is with the power off, place an amp clamp around the "common" wire from the compressor. Now turn the power on and check what your amp draw is. If there is no amp draw, then the compressor is not running. Why is the compressor not running? When you say you "checked continuity of the compressor, ok" I take it that you found your run, start, and common windings, and that by doing a little math you determined everything was good. If this is the case, then check to make sure the capacitor is good, and any starting relay that might be used is in correct working order. Hope this helps
    May 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Not cold
    If the compressor seems to be cycling as normal, either the system needs recharged or the temperature controller has failed. If the compressor is running at all, it is probably OK.
    Diagnosing it remotely is only guess-work, I recommend (if in the US) that you check with the local BBB for a trustworthy service company to assess your unit.
    If a recharge is needed, this is not a DIY job since it requires opening a sealed system and soldering it shut after the coolant is at the proper pressure.
    Replacing the temp controller might be possible but better done by a pro since the location of the sensor tip may not be easy to find.
    Another (albeit less likely) is the failure of the defrost timer which could keep the heater on while trying to cool.
    The timer is often located behind the lower trim grill and should be a small box with connections.
    Some have a slotted shaft protruding from the case that can be turned with a common screwdriver.
    Checking the switch contacts inside can be done by waiting until you hear the compressor running and then slowly turning the shaft until the compressor shuts off again; this would represent the defrost cycle.
    If you advance the shaft another 1/4 turn and leave it there, after the compressor stabilizes again, it should turn on.
    Mark the position of the timer shaft and then recheck a couple of hours later.
    If its shaft has turned, the timer is probably OK.
    They typically have either a 24 or 48 hours cycle so the shaft movement isn't easy to detect over a few minutes time.
    Good luck-
    Apr 22, 2010 | GE Profile PSW26P Stainless Steel Side by...
    The refrigerator is not cooling
    If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
    Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
    AMANA SxS REPAIR MANUAL
    BOSCH MANUAL
    Monogram Manual
    KitchenAid SxS with variable capacity compressor
    GE LATE MODEL SxS MANUAL
    F&P Reefer
    Jan 11, 2010 | Maytag Refrigerators
    Kenmore SxS 596.52673200 stopped cooling
    You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
    Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
    I have a GE SxS that I bought in Sept. 06. About
    First you need to turn the freezer temp control back on(That just turned the whole refrigerator off)
    The water dispenser may have stopped due to line freezing inside the refrigerator.
    The ticking could have been the the element for the defrost cycle or the starter on the compressor.
    So,turn it back on,set the temp to a normal setting and if the ticking is still there,wait 30 minutes to see if it stops,If no ticking is there when you restart it,wait 24 hour and check the temp inside as well as the water and ice dispenser,If all work,It is a defrost issue.If so you will either need a defrost timer,defrost element,or defrost thermostat.
    If the ticking is still there,You will need to replace the start/run capacitor.
    Apr 16, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
