When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
How do you know toner is not low? You can't get rid of the message. The toner sensor is within the printer, and if it says 'toner is low', then it either "is" or the sensor is defective.
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
(blinking every 5 seconds)
Toner Low
Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated.
(solid)
Toner Empty
Replace the toner cartridge with a new one.
User's Manual is available at the following location:
http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf
Hope this helps.
