Question about Canon PowerShot A75 Digital Camera
Not Switching between Shooting and Playback
Often, when the switch is in "shooting" mode, the camera switches to "playback" mode after a second or so and I can't take a picture. I suspect the mode switch needs repaired but not sure who does this or how costly (now out of warranty.
Well depeneding where you live, you should call canon and find out where the nearest canon store and you can also ask them how costly the repairs will be... i doubt very much seeing as it is an internal problem... but ask just the same...:D
Posted on Feb 18, 2007
Playback switch does not operate
PDF]Camera User Guide
gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf
Switching between Shooting and Playback.....32 .... Please note that Canon digital cameras are intended for personal use and should never be used .... Do not operatethe flash with dirt, dust or other items stuck to its lens. ..... PowerShot A520:.
Repair tips for digital cameras that won't power on. 'Do It ...
camerarepair.blogspot.com/.../simple-fix-for-dead-cameras-that-wont.ht...
Nov 30, 2007 - It was a fix for a Canon A520, but am not sure if it would work for ..... I have a Canon Powershot A540 which will not turn on and lens is stuck out extended.... (even when they are new) in camera mode and not playback mode.
Digital Cameras - Canon PowerShot A520 Digital Camera ...
Dec 02, 2015 | Canon PowerShot A520 Digital Camera
Canon powershot only boots in playback mode
You could try to help the lens coming out if you hear the motor trying to. Or hold the camera with the lens downwards to let gravity help as well. Hope that will help. Or the lens mechanism will be faulty and the whole lens needs to be replaced. But such a repair might not be worth it because of the costs and the value of the camera.
Jan 04, 2014 | Cameras
Hi, I have a Canon Powershot A700 digital camera and I am facing a problem with it. The 'Mode Switch' button, which changes the mode from Shoot/Record mode to Play/View mode is not working....
If you have the manual for this camera turn to page 15.
This tells you how to switch between Shooting Mode and Playback Mode.
This is achieved simply by pressing the DISP button.
This button is located below and to the left of the FUNC/SET button.
Pressing DISP repeatedly toggles between Shooting Mode and Playback Mode.
I would suggest you try these steps with your Mode Switch in both positions alternately.
May 20, 2011 | Canon PowerShot A700 Digital Camera
I was taking pictures and was switching between different shooting modes; on the manual mode when i was changing exposure settings, suddenly a msg came on the centre of the screen saying 'Access...' and...
Semiconductor chip for manual control may have over heated. Try using DC power supply to room temperature anneal the chip.Turn on playback for a while, until the camera does not heat up. And then try batteries fully charged to see if the chip can be annealed, and working again. Otherwise, you have to disassemble and replace the chip or subassembly..
Aug 14, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Ricoh Caplio R7 focusing problem
Go into the menu and find "reset"...follow the on-screen instructions.
Feb 24, 2010 | Ricoh Caplio R7 Digital Camera
Shooting/playback mode switch
in the end it was my memory card which suddenly went faulty.after formatting it, (see above added comment) it worked for some pictures then i switched to playback and this time it said memory card error and shut down. well if it would have said this in the first place would have saved a lot of trouble i almost threw the thing away.(the camera) so i puts a new card inside and its working like new, all the playback i can handle. goes to show its not always as bad as it looks with a little patience.....merci
Feb 27, 2008 | Canon PowerShot A520 Digital Camera
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Dial on the top
This dial is the mode dial. It allows you to switch between shooting mode, recording mode (movies) and playback mode.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
The dial on the top
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
