Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a John deere 316 with a onan and it will not run unless the choke is almost closed, I have checked the fuel flow and the compression and all seems good. What do you think is wrong?
  • John Deere Master
  • 2,760 Answers
If it runs in choke only then it's fuel starved it's either the fuel filter or the fuel pump
Posted on Oct 15, 2013
    Sergeant:
  • 316 Answers
Hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Posted on Feb 23, 2012
nova2nv
  • 197 Answers
SOURCE: john deere 318 wiring diagram I replaced an bg 316
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Posted on Nov 16, 2009
Testimonial: "This was great advise bought a solenoid and away i go thx"
  • 3 Answers
SOURCE: my john deere 316 stopped moving forward and
HAVE YOU CHECKED THE TRANSMISSION/HYDRAULIC
OIL? THEY ARE THE SAME. ON SOME TRACTORS THIS
CAN BE CHECKED AT THE REAR OF THE TRACTOR JUST
BELOW THE SEAT. IT COULD ALSO BE A BAD HYDRAULIC
PUMP.
Posted on Jan 02, 2011
rycgl
  • 1545 Answers
SOURCE: I cleaned my carb on
On most float-type carburetors, the float is usually perpendicular to the edge of the carburetor body when the needle is seated.Turn the carb upside down and adjust the float if necessary, to where the float is parallel to the carburetor bowl mounting surface. There are tangs at the front of the float where it hangs on the pin that can be bent up or down to accomplish this.
Posted on Jun 18, 2011
  • 24 Answers
SOURCE: how hard is it to replace the starter on a john
Not hard at all, disconnect battery than remove battery cable from starter, should be just one nut.there's a smaller wire that should just unplug, than there there should just be two bolts holding the starter in place remove them and you should be able to slide the starter out.
Posted on Sep 14, 2011
  • 123 Answers
SOURCE: John Deere G049K Snow Thrower Service Repair
An older snowthrower will make some noise, but it depends on what kind of noise you are hearing. A "growl" is not common and can indicate the gearbox is low of oil or the oil needs to be changed. The gearbox is mounted on the back of the snowthrower and there will be a dipstick on top. There should be oil on the dipstick, and it should be kind of thick. Proper gear lube is 80-90, and should be a gold color. Also check to make sure the auger bearings are not going bad. You can grab ahold of the auger while the machine is off and try to wiggle it. If it moves at all the bearings will have to be replaced. Start there and let me know if you need anything else, Daniel.
Posted on Nov 04, 2011
My John Deere 420 onan stops for no reason after running for ten minutes Restarts immediatly.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
John Deere 316 318 and 420 Lawn and Garden Tractors Service Manual
Jul 07, 2015 | John Deere Garden
Does a john deere 316 engine have a compression release when you first start it.
you may have a weak or undersized battery on it .or the starter is getting ready to kiss this world good day .
May 30, 2015 | John Deere Garden
My john deere 316 loses power going up hills and when I have the mower pot on
Sounds very much like a fuel issue, i.e., starving for fuel. Check the fuel filter and replace.
Aug 04, 2014 | John Deere 300 / 316 Hydrostatic Tractors...
Engine runs on idle and full choke, but does not run at mid throttle settings
Does it use gravity or a pump? If gravity, check the fuel line for internal disintegration. Air filter is clean, right? If your float does not move freely, it can restrict fuel flow also. Need for choke indicates that fuel is not being supplied, so check that it can flow by loosening the float bowl and catching the fuel. If slow, remove the bowl, and check the unrestricted flow.
Dec 17, 2012 | John Deere Garden
John deere onan 316 over reving
see if the governor gear maybe striped
Apr 03, 2012 | Garden
John deere 318 wiring diagram I replaced an bg 316 onan with an bg 318 onan new the starter only has one bolt for wires the old one has a bolt and a plug on where does the purple wire go on this new...
Sep 28, 2009 | John Deere Garden
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
781 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
