Question about Lexmark Office Equipment & Supplies
We purchased a new H/P laptop and when I insert the disc wegotwith the printer Lexmarkx125 it cannot find the device software for the printer. We bought the printer in 2002. Mrs. B
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
If your New HP Laptop is Vista you might need to go to Lexmark.com and search for the Vista drivers.
Posted on Oct 27, 2008
  • Mike S
    Mike S Oct 27, 2008
    Your printer was made in 2002, vista was released January 2007... I am only assuming your PC is Vista.. as there have been so many problems with drivers for Vista..
    If you hook this Printer to your PC via USB. I believe it might install, the drivers might already be there for it.
    Not certain about that thou?
I want to install my epson stylus sx520w printer onto a new laptop. i have the disk but no manual
Go insert the Epson Stylus Printer's driver disc to your new laptop and if you installing or installed the printer's software?.... it can teach or you have learn how to use printer from it. JUst like where desktop or PC you were installed the printer before.
Aug 20, 2014 | Epson Stylus Office Equipment & Supplies
Replaced printer, same laptop with software. Inserted new DVD, but laptop does not give instructions for connecting printer.
It is possible that the auto-run feature has been disabled. Try opening the CD manually. If you have Windows, double-click on Computer (My Computer for older versions). Then double-click on the optical drive under Devices with Removable Media. Find the installer (exe for Windows, dmg for Mac) and double-click to launch it.
If the optical drive doesn't open, then you have a problem with the disc, the drive, the drivers for it or the registry properties for the drive.
If the disc install the Easyshare 5500, download the drivers for supported OS versions from here: http://support.en.kodak.com/app/answers/list/p/5,62,419/c/890/selected/true . Then double-click on the file to install. (If you plugged in the data cable (USB) to the computer before installing this software, uninstall the generic driver and then disconnect the data cable and reboot before installing the new software.)
Now to go back to the drive problem, if you were able to launch the file from the File Explorer (Windows), you may want to reenable auto-run. In Windows 7, click Start > Control Panel > Hardware and Sound > Autoplay. Set the line for Software and Games to Install or Run. You may want to check the box to Use AutoPlay on all media. If the optical disc could not be read, try cleaning the disc (if you see scratches) and try cleaning the optical disc lens. (Did you here the disc spin when loaded?) Check the Device Manager for a triangle with a red x or yellow exclamation point next to the optical drive. (Start > Control Panel > Hardware and Sound > Device Manager) Try to update the driver.
If there was no sound of the drive spinning, you may want to check if the power or data cable have become disconnected inside the laptop (either at the motherboard or the drive). See your laptop's documentation for opening it up or take it to be serviced at a local shop. You may need to replace the drive. An external optical drive can be used to replace the internal one and are fairly cheap. Most connect to one or two USB ports on the computer. The ones that take two USB ports do not need a power brick.
I hope this helps.
Apr 23, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
I need reset my laptop back to factory setting, so i need to know who to format the HHD. how can i do this.
I eally depends on the make of laptop.
Toshiba use F8 for restore, HP F11
Have a look in your manual, it will let you know where the rescue partition is, indeed if it is still intact.
Feb 14, 2011 | Computers & Internet
Sir i purchased hitachi camera pen. it is detected
If you have installed the program. Uninstall it.
Unplug the pen (or any devices associated with it) from the computer.
1. Insert Disc and intstall the program.
2. When prompted, insert the device into the computer as instructed. Follow all instructions.
3. Once installed, remove disc, restart computer.
4. The computer will detect the device as the computer is loading. Wait for all "start up" programs to load, then select the program and it should open and operate.
If it is plugged into a USB Port, and is not being detected, try using another port. Do not plug such utilities into a Port Adapter, as it most likely will not be detected.
It must be plugged directly into a USB Port installed on the computer (or laptop).
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jul 17, 2010 | Hitachi Dynamic Link Manager 5.4...
I have downloaded the HP software to my laptop since I no longer have a disc, I have XP but my printer will still not print; it states it is printing but then does nothing...help I have tried restarting...
You can download the driver from HP and install it even before you plug the printer, then it will not ask for more drivers. Uninstall every copy af your printer first.
Mar 05, 2010 | HP LaserJet 1012 Printer
I recently purchased a new laptop with Vista. Our
Try this web site, choose your OS version, then download what you need:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=446154&taskId=135&prodTypeId=18972&prodSeriesId=446153&lang=en&cc=us&submit=Go%20%BB
Good luck
Aug 21, 2009 | HP Color LaserJet 2600n Printer
LexmarkX125 will not scan documents to computer
uninstall the printer turn off you fire wall and virus protection. and reinstall the software. windows firewall and some security programs block the nt drivers needed for scanning. do you get a message saying window has blocked some start up programs?
Mar 26, 2009 | Lexmark X125 All-In-One InkJet Printer
Need download from computer for my lexmark x125 printer-fax
Click here for XP/2000 driver download from Lexmark to suit.
Please rate as fixed
S.
Nov 19, 2007 | Office Equipment & Supplies
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
