Question about Dell 3010cn Laser Printer
Dell 3010cn error code 077-900
My Dell 3010cn was printing just fine. And then all of a sudden just stopped. I keep getting error code 077-900 whenever I try to print saying I have to clear a paper jam. It started to pull the sheet then just stops. I reset the printer and the same thing just keeps happening. What can I do?
Vegggie Boy
  • 28 Answers
SOURCE: Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Posted on Jul 28, 2007
futureloginn
  • 734 Answers
SOURCE: Dell 3010cn paper jam 075-134
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
SOURCE: Dell 3010cn paper jam 075-134 cannot get rid of error
The reason Dell said this problem was almost impossible to fix is because it is. There is a lift mechanism inside the housing for the MPF paper tray that lifts the paper to the roller to pull off the top sheet. The lift mechanism in this printer model is flimsy at best. There is a roller cam with a knuckle attached to it to does eventually break, causing a failure of the lift mechanism. The components to repair this problem are unavailable from Dell, and can only be salvaged from another printer. Here's the kicker... You have to disassemble the ENTIRE printer in order to replace this assembly. This took me 2 and a half hours to accomplish, and you're going to have to do it on 2 printers, as well as reassemble the fixed one. DO grease the cam assembly with some white grease to get the longest life possible if you choose this option. Best option? Either purchase another printer off eBay with a different problem and use yours to fix that one, or, as Dell so lovingly suggested, purchase a new one. The cost of today's color laser solutions make purchasing one of these printers a much more viable option than fixing your 3010cn.
Posted on Aug 31, 2009
SOURCE: Clear Paper Jam message on my Dell 948 nAll in One
press cancel button,, for 30 seconds, it will reset, either, press, on/ off button once.
Posted on Jan 17, 2010
matt2414
  • 247 Answers
SOURCE: Dell 3010cn with error code 077-300
http://www.fixya.com/support/t2261865-error_code_077_300_close_front_cover
Posted on Mar 27, 2010
Dell 3010cn error code 077 303 Close paper cover paper cover is open. Which is the paper cover and what can I do to get it going?
The Paper Cover is located on the top of the printer. It is the vented panel just behind where your printed documents come out. It lifts up to clear paper jams, and documents won't print until it is closed. Just push the panel down until it clicks in place...that should do it!
Jan 03, 2011 | Dell 3010cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Getting 004-332 restart error
Hi
Error code: 004-332
1. This type of error code implies that you need to restart the printer again.
2. However, do check to see if toner cartridges are seated in the proper position.
3. Also ensure that they have been locked in.
This is an error commonly associated with the Dell 3100cn laser printer.
Jul 14, 2010 | Dell 3010cn Laser Printer
Borderless printing with a dell 3010cn
This is application driven and you will need to set this up from your application or when you File / Print select the Print Preferences for the Dell 3010cn and then select borderless printing
Sep 30, 2009 | Dell Office Equipment & Supplies
Problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Feb 10, 2009 | Dell 3110cn Laser Printer
Dell 3010cn DRUM
The information I have on that error is as follows:
From the Dell TS Guide:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&cs=04&journalid=4D4C014288160766E040A68F5A283437&l=en&s=bsd&treeid=DCD92482F5548BF9E030A68F27281FC1&Query=ZHJ1bStlcnJvcg==&SystemID=PRN_LSR_3010CN&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
1. Replace the cartridge with a new Dell Branded one
2. If cartridge doesnt resolve, replace the left Intermediate Belt Transfer (IBT) guide assembly.
3. If that doesn't fix, replace the Machine Control Unit (MCU)
May 15, 2008 | Dell 3010cn Laser Printer
Dell 5100cn Laser Printer Problem
My Dell 1600n suddenly stopped printing. It keeps saying "No paper," and even though I've changed papers, fanned it, squared it, changed how much, how little.............it still says "no paper."
Dec 27, 2007 | Dell 5100cn Laser Printer
Dell 3010cn Laser Printer Logo
497 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
