Question about Citizen Eco-Drive Calibre 8700 Wrist Watch
Cant change the date - Citizen Eco-Drive Calibre 8700 Wrist Watch
Coleman watch is on but cant change the time
Try this site:
http://www.ehow.com/how_8204646_set-date-coleman-watch.html
Jan 21, 2013 | Watches
I am assuming the day changes but not the date. There is a halfway setting on the stem you pull two clicks to set time , one click to set day/date, turn one way for day of the week other way for date. If your actual date is sticking you can try going round and round with the hands (takes awhile) to set it! I have noticed the date is the first thing that goes on these watches. If that does not work it will have to be repaired by a watch repairman. hope that helps:)
Aug 28, 2011 | Watches
I cant set the annalogue hands
Use the crown to set the time. Advance the time by turning it clockwise. Watch the day/date window and when the day/date changes that is midnight. Now that the a.m./p.m. mode is set correctly, advance the time to the one you wish to set it to.
Mar 28, 2011 | Watches
I have a guess steel watch , and i have set my date and time right , but i cant put the day right , so monday or tuesdag for example.
Advance the watch time 24 hours to change to the next day. keep turning until it reaches the corect day of the week, then reset the correct time and date.
Nov 14, 2010 | Guess Watches
I cant adjust the date for my Fossil AM4205..help!
mcdevito75 here, If your Fossil watch has a winding stem it may have 2 positions, gently place a fingernail under the crown and lift as gently as possilble, this should allow you to adjust the date without having to cycle thru the 24 hours to get to the date you want. It may take practise but that first position should be there, Set the date to 1 day before the date you need, then set the watch normally the full 24 hour cycle to get the date you want, this way the watch date will set as suppose to at about mid-night for the next days date.
Aug 28, 2010 | Watches
Citizen 2100 cant set date
Sounds like a return to the manufacturer to me, you generally only get two clicks one for the date one for the dial hands. But try one click and turn in both directions, or two clicks go to 11:59pm through 12:00am back and forward and see if it will change date that way.
Good luck, and a merry Christmas.
Dec 23, 2008 | Citizen Calibre 2100 AV0031-59A Wrist...
I cant reset the time on my watch it is a stark -1082
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Oct 28, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
Change day
The trick is to turn the ring to the "Date" setting, Pull the stem out once for the Month and Date. Pull the stem out (hard, but gently) a second time for the Day of the week. Each pull will be confirmed by a 'beep. Be persistent and good luck.
Oct 15, 2007 | Timex Men's Black Reef Gear i-Control...
Citizen Eco-Drive Calibre 8700 Wrist Watch Logo
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
