Question about NorStar Lands Phones
Nortel 824 doesn't hold memory after a power outage
Norstar 824 memory defaults if there is a power outage. Do I need a replacement software cartridge or a KSu?
  • Carl Navarro
    Carl Navarro May 11, 2010
    IIRC the battery or cap is in the s/w cartridge. Best to call your Nortel dealer.
I though that the battery or capacitor to hold the memory was in the s/w cartridge but I wasn't sure. I reprog a couple of things then cut the power and the system reset to default values again so it looks like I need a new DR5 cartridge. Thanks for all the help. F.K.
Posted on Oct 27, 2008
How do I fix voice mail and auto attendant features lost on Nortel Norstar mics 4.1
You can restore a recent configuration backup from diskette but if you don't have a backup you will need to rebuild the configuration from scratch. You may also have a failed hard drive or a failed supercapacitor that did not retain memory when the power was cycled. These components will need to be replaced before you continue with reprogramming.
Apr 25, 2014 | Nortel Norstar Modular ICS MICS 4.1...
How do I reset my phone system? Nortel Norstar
It's simple.
On Vmail it's Ftr 983 -> pswd -> 1 -> reinstall -> yes
On MICS it's pull the power plug off and within 15 minutes -> Ftr** -> startup -> pswd
To be sure follow the users manual instructions. You can get the pdf user manual here: Nortel Norstar pdf manual
Sep 17, 2013 | Nortel Norstar Compact ICS 6.1 Software...
Power source
A Nortel Key Service Unit, an ICS (MICS,CICS), BCM (50,100 etc), Norstar (308,616,824), an Avaya IP Office running Nortel cards, or there is another company that makes a Nortel emulation key system but I can't recall what it is right now.
Carl
Nov 23, 2012 | NorStar Meridian M7310 Phone
Power outage now you have to select a line manually instead of just picking up phone and it's taking awhile before it starts ringing
What usually happens after a power outage is the system defaults because the backup battery in the memory card is dead. That means 2 lines only on every phone, pulse dialing, and all phones ring. If your system looks like that, it's time to call the Nortel repair tech. He can replace the battery or software module with a new one and reprogram the system.
Carl
Aug 17, 2010 | NorStar M7324 Corded Phone
We have lost power a couple times this week and our system had reset, losing our third line and voicemail greeting will not prompt when suppose to. We still have out greeting, it is just not picking up.
What type of System is it? Norstar systems default to 2 lines if they loose memory (which isn't supposed to happen). That being said, I recently had had to replace an old Norstar 616 that would not hold memory after a power outage. I took the KSU apart and could not find any internal battery to replace. I'm guessing some kind of capacitor ?? In any case the system had to be replaced. Bill C. www.dyna-tech.us We also do remote programming on Norstar CICS ans MICS.
Mar 26, 2010 | NorStar M7310 Corded Phone
How do I program the speaker to work?
You have lost system programming. Unless you are well versed in getting into your system with the installer password, you need to call a Nortel service tech. The older systems have a battery backing up the memory and when it dies, your system crashes. It's really obvious, because it goes back to the default of only 2 lines working and all the buttons become defaulted.
Entire systm programming is beyond the scope of this forum. I do have a CICS programming sequence on my website http://www.public.carl.airpost.net/Nortel/CICS_Programming.pdf
It would be unlikely that your system is a CICS, but this is an idea of where the programs are and what level you need to access them.
Carl
Dec 08, 2009 | NorStar M7310 Corded Phone
Problem with power supply in PBX o KSU
Power supplies come with the main chassis. You may need to have the chassis replaced. are you sure it is receiving power ok? You can replace the cards and the flash card into the new chassis and restore programming.
Oct 21, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Nortel Admin Password Problem
You use the f985 to reset the password. But i cannot publish the password here. It is in your vm manual.
Aug 09, 2009 | NorStar M7324 Telephone
NorStar ICS Caller ID Upgrade
Yes, this is correct. install the co card with cid and you should be fine.
Dan
Jun 07, 2009 | NorStar Compact Ics WithClid Trunk Mod...
Nortel norstar
ON NORTEL DO A FEATURE 983 PASSWORD IS GOING TO BE 120000 AND THAT WILL PROMPT YOU THRU RESETING THE PASSWORD IF THAT DOES NOT WORK DO A FEATURE 985 PRESS 9THEN TYPE IN (RESET SM ) THEN TYPE IN (PSWD) AND IT WILL GO BACK TO DEFAULT . PS THE SM STANDS FOR SYSTEM MANAGER
Jan 25, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Lands Phones Logo
307 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
