Question about Dell Latitude E6500 Laptop
SD Card Stuck
I put a new SD card into the card reader and it will not come out. I tried pushing it in further to spring back, but it just got stuck in even further. Is it because it is an SDHC card? How do I get it out?
    Genius:
  • Dell Master
  • 1,274 Answers
Gah! the only thing i can think of is to try and get something flat and thin, like thin piece of plastic, and try and wedge it out, if you can't wedge it out, the only thing i can think of is needle nose pliers. if someone else has a better suggestion please speak up, but that's the only thing i can think of.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Posted on Feb 23, 2012
4 Suggested Answers
Nowuser
  • 56 Answers
SOURCE: SD Card Reader
Look into the device manager for Recoh drivers.reinstall them.Also try the card in a different system or different card in the same system to check if they are working fine.If still not working than u might have to get the motherboard replaced
Posted on Dec 26, 2007
Felinna
  • 42 Answers
SOURCE: Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Posted on Feb 23, 2009
SOURCE: HP IPAQ 1930 does not hold the sd card.
pls i want dell inspiron 1525 drivers .pls help us.
Thanx
pradeep
Posted on Jun 01, 2009
How do i get my micro sd card out of the slot on my asus memo pad, its stuck and i cant see it
The card reader slot is shorter than the memory card itself, so it sounds like you didn't put the SD card into the card reader but rather, into some other kind of slot. If you cannot see the card at all, try straightening a wire such as a large paperclip or something and try using a flashlight so you can see to try and fish the SD card out. If you can't do it, you will have to go to the local computer store for them to try for you.
Apr 26, 2015 | ASUS MeMO Pad HD 7
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
I have a camera that carries a 1GB SD and when it is inserted in the camers the camera says the card is locked, but the switch on the side of the card shows it is not locked. what can I do?
Spray dry air or contact cleaner into card slot to remove any debris...work card in and out several times should have a push-push action...pushing in card should slightly spring back...push again card should pop out a little.
Sounds like latch that catches and holds card is broke or stuck...hope it's stuck!
Jan 01, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Plastic stuck in 5-in-1 Card Reader
normally this is a dummy card to prevent trash from getting in the slot. you should be able to push all the way in and when it pops back out remove it. (just like a sd card)
Please rate this solution if it has helped you.
Thanks, Gary
Jul 13, 2010 | Acer Computers & Internet
Sony memory stick is stuck in SD slot on my HP Pavilion dv7-1279
First, with the battery removed, a tweezer or thin paper clip.
Sep 22, 2009 | HP Pavilion dv7-1279wm Notebook
Sd card stuck in slot
you will have to remove the palm rest and then unplug the sd device look in the back of it and should be a small hole take a paperclip and push through the hole
Jul 27, 2009 | Toshiba Satellite L305-S5933 Notebook
My micro SD card got stuck in my LG Vu phone
Yes there are 2 different places for the SIM card and memory card in the VU, but they are very close together. Try using a small pair of tweezers to gently grab both sides of the card and slowly pull it out.
Jul 27, 2009 | LG VX8300 Cellular Phone
Multi-media card reader problem
Try pushing in on the card until it clicks, and springs back out. If it is not that type of slot, then pull the card out using a pair of needle nosed plyers (since you obviously can't pull it out by hand). If it looks to require too much force, then you might want to try taking out the screws on the back of the laptop to reveal the card slot, there is an obstruction that is preventing the card from being removed. I had an issue with an SD card getting stuck, and I pulled it, but the pins stayed inside, so use caution & be gentle.
Dec 12, 2008 | Lenovo 3000 Y410 Laptop
Stuck Mini SD Card in Blackberry BOLD, 9000
same thing just happened to me... i had to use a small pin to *gently* pry the card out.. i am now reluctant to put it back in but atleast its out...
i have a feeling it might have been inserted incorrectly but as the sales guy did it at o2 im not sure...
good luck
Dec 12, 2008 | AT&T Blackberry Curve 8300 Smartphone
CD & SD Card stuck in Asus Pro31F notebook
gant really help on the sd prob.sd usually push in to insert and push in again to remove.
cant imagine how you can get cd stuck between rom and chassis.anyway if you look closely at your rom you will see a small hole.you push a thin piece of wire into this to eject the rom hopefully giving you more room to play with and remove disk.a paperclip made straight is an ideal tool for this.
as for repair;tell me your model and i'll check to see if I have it
I have nearly all hp service repair manuals,some toshiba and ibm
Mar 03, 2008 | Computers & Internet
Dell Latitude E6500 Laptop Logo
154 people viewed this question
Alun Cox
