Question about Sewing Machines
The zig zag stitch width is inconsistent and skips occasionally, what could be the problem?
The straight stitch works fine. The length setting is fine. It's just when I zigzag or try to move the needle over to the far right position, it won't go.
SOURCE: Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
Posted on Oct 30, 2007
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
  • 1027 Answers
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
  • 55 Answers
SOURCE: bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Posted on Jul 27, 2009
White 1521 only zig zag even on straight setting had it cleaned but still only zig zag zig zag on all setting how or can it be fix?
I don't think it needs to be fixed. If you want to zigzag, there are two setting you need to do. One is the stitch length and the other is the stitch width. When you sew a straight stitch, the width is 0. If you want it to zigzag, make the width wider (usually 1, 2, 3, 4, or sometimes 5). I've looked at the manual for this machine and page 21 has some info. There's probably more if you read further. If you don't have a copy, go to singer.com. They have tons of manuals for many brand of machines. Click on the support button and go from there.
Dec 02, 2017 | Sewing Machines
I want to baste and dont know how to set straight stitch and length.
To baste, set the stitch length as high as possible (zero is a non-stitch length, probably 4 or 5 on your machine is the largest stitch length). Set the stitch width to zero so there is no zig-zag.
Jan 09, 2017 | Sewing Machines
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
Why won't my zig-zag zig zag?
Check your stitch width setting if its too low it will just straight stitch.
Jan 21, 2015 | Sewing Machines
My Kenmore 19233 refuses to zig zag stitch past 2mm wide. At 2mm it is a reliable stitch, moving toward 7mm it is a straight stitch with one or two zig zag blips.
Do you have it on zig zag or maybe it is in one of the hem stitches. Make sure you have not selected a special stitch. Sometimes with a small width setting it looks like no zig zag, then when you increase the length you see it is not.
Oct 20, 2014 | Kenmore 19233 Computerized Sewing Machine
My machine will not zigzag. Width setting on on1 length setting on widest
You need to take the width setting up to 4 and length down to 2 or less if you want a close zig zag. You may not want it that wide but usually 4 is the maximum width.
There is probably also a stitch selector if your machine has several stitch patterns it can do. I've looked at an image at http://www.stevekraftrepair.com/uploads/resized-P9200750.JPG and it looks to me like the left hand knob on the front of the machine is the stitch selector and is colour coded in with the images on the front panel. I just can't make out which number is the zig zag, it could be the red number 4??? So you would put this dial onto the zig zag, then turn the other dial up to a wider stitch width and I am guessing that the little blue box lower down the case has the reversing button and the stitch length setting.
Usually it pays to turn the width to zero BEFORE you make changes to the stitch selector, most machines seem to like being treated this way, ie engaging cams inside the works.
Also, it is always a good idea to check what foot you have on before you start sewing a swing needle stitch just to make sure that you don't hit the foot with the needle. Some feet are designed for straight stitch only and have a little hole but obviously this is not going to work for a zigzag stitch.
I hope this is of help and that I have understood your problem.
Jun 11, 2011 | Necchi 3537 Mechanical Sewing Machine
I cannot get my sewing machine stitch the different stitches. I've followed all the instructions in the manual and all I get are straight stitches. I want to get a zig zag. Sometimes it looks like it did...
When you select a pattern does the needle move back and forth? do you make sure the stitch width lever is on straight stitch then select your pattern then select the widest stitch width? if when you select a zig zag stitch the needle does not move from side to side then you need to look in the top at the finger that goes round the cam.
Nov 04, 2009 | Singer 2732 Mechanical Sewing Machine
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Need a straight stitich How to make the machine do a straight stich...not reponding to settings
not sure which model you have but you should have a stitch length control and a stitch width control. locate the stitch width control and set it to zero.
if you have done this and the machine continues to zig zag the zig zag mechanism inside the machine is most likely seized up. try lubricating all linkages inside and move the control lever a few times to see if it will free up.
if not you may need a tech to service the machine.
scott.
Jul 28, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
121 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
