Question about Lands Phones
Vodavi cid-9 installation
This is an old system, but I have it working good in my tax office using vonage and magic jack plus. I bought a CID-9 unit from ebay, but I'm unsure how to hook it up. I know it uses the RS232 ports, but is straight DB9 cable or null modem? Do I split each phone line (one for Key system and the other for CID)? I cant find any documentation. Any help would really be appreciated.
  • 279 Answers
SOURCE: Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Posted on Oct 08, 2007
Silan
  • 54 Answers
SOURCE: Fax - Using Vonage
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off. Try sending FAX.
Posted on Dec 22, 2007
SOURCE: cid issues
Are you getting caller ID?
Under phones/sets, you have to tell the system to log the calls.
Posted on Jan 09, 2008
Maanita
  • 1142 Answers
SOURCE: Where do you connect a External Paging Port on Nortel Key Telephone System NT5B05?
This will help you
http://assets.twacomm.com/assets/pdf/4230.pdf
Posted on Jul 03, 2008
BAD421
SOURCE: NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Posted on Aug 02, 2008
My Uniden Dect handset has stopped working. No dialtone. Also message on handset reads:'New CID:50'
CID(caller identification) your phone logs incoming calls in it's memory. The #30 signifies that there are 30 CID(phone #'s) logged in the memory of phone from callers. The phone saves the information for the last 50 received calls to the CID list. The NEW icon marks any calls received since the last time you checked the list. You can delete these one by one or all by pressing ID (CID# will come up) then press menu/select button I believe 3x and repeat until all unwanted CID's are deleted. page 9-10 of the Dect 6.0 manual below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button. https://www.101phones.com/content/pdf/un...
So your problem isn't related to that message. Disconnect your unit from the wall plug. Remove the handset battery, count to 10 and put it back. Plug the base unit in and try again. You need to check the line jack with a standard phone to make sure the line is good.
https://www.101phones.com/content/pdf/uniden/D1760.pdf
Dec 06, 2017 | Uniden Lands Phones
I bought a magic jack plus my old magic jack broke I pluged the new one all my contacts came back but I can only receive calls but I can not call out
Lets try this. When you installed your new magic jack, did you install the new software from the website, or did you just plug it in and go "HEY all my peeps are here. We are done?" Install the new software from magic jacks site and if you did this then and it still doesn't work, then i am out of ideas for this one. Only other thing i can think off is in your settings and you have it on incoming calls only.
Mar 15, 2014 | magicJack Plus Pc To Phone Adapter
Old majic jack want to start new program
If you have an old Magic Jack, my 4 unit are 6 years old the company just really wants you to upgrade to a newer product no need to. Try removing Magic Jack completely from your tablet, restart unit, make sure to clean out all junk on tablet from Magic Jack you could try a program that cleans your tablet for you, but unless you know what to remove don't get technical just a standard clean up of old files, this is usually under apps, Magic Jack, then there will be a clear cash button, clear data, and uninstall.
Restart unit then do a fresh install of Magic Jacks new app for your type of tablet from Googles sight or Magic Jacks make sure if you have a Mac to install the Mac App and if you have an android tablet you install the Android App. This has been working for me. With the old Magic Jack you will need to do a fresh install when you get errors and crashes. I do it 2 or 3 times a year. Good Luck!!
Jan 06, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
New phone DECT1480. How do I delete the new cid numbers
To select a number, highlight the number and press Menu/select. The phone gives you the following 3 options:
1) Delete Entry Erase the number from the list.
2) Store Into Pb Add the number to the phonebook. The handset prompts you to edit the name and number.
3) Delete All (CID list only) Erase all numbers from the list.
Friends phone:
1) Check batteries
2) Check base unit has good mains connection ! faulty mains extension
Oct 18, 2017 | Uniden Lands Phones
How can activate caler id in panasonic kx-t7730
CID comes from a card installed in the phone system, CID service from the telco, and programming of the system, and your phone has to be ringing to display CID. If others have CID and you don't check ringing first. if no one has CID, then check to see if you have the card in your system. It will have a part number ending in 93 as in 62493, 82493, 84893, etc. and be installed inside the cabinet. After that, your Programming manual will have instructions on how to make it work.
CID only works on TA-624 and higher systems.
Carl
May 19, 2011 | Panasonic KX-T7730 Corded Phone
Can not pull caller id log. How do you do this?
Besides system programming of what to do with the 301st call, you need to program 2 lighted buttons on your set for 96 and 97 CID Indicate-Common and CID Select-Common. It will now display all CID calls into the system, assuming you have CID working.
This is for the TA-824 series Key Service Unit, which is a common system for the 7731 phone to be connected.
Apr 16, 2010 | Panasonic KX-T7731 Corded Phone
Just plugged caller id box in to panasonic kxt7420
There is no such thing as correctly plugging an analog caller ID box into a digital phone line.
CID display comes from a TD-193 card mounted in the Key Service Unit and it only displays on Panasonic system display phones designed to work on a TD system. The only system that passes CID through to stations is a TA-824 and certain models of TDA-s that have special analog extension cards.
You can use the analog box, but you have to bring the line from in front of the system to the CID box.
Carl
Nov 11, 2009 | Panasonic KX-T7420 Corded Phone
Is it possible to fax over a regular VONAGE line?...
Forget Vonage, magic jack is only $20 per year and I see no reason why you couldn't fax with magic jack
Jun 16, 2009 | Dell A960 All-In-One InkJet Printer
Lands Phones Logo
57 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
