Question about Xerox Phaser 8560MFP Laser Printer
Printer is not online
Printer will copy, but when I send a print job to the printer, I get a message that the printer is "not online".
    Top Expert:
  • 1,575 Answers
Hi
Printer 'offline' right?
Turn it off and on.Solved?
Clear any print queues.
Disconnect the printer from the PC and from power.
Reboot the PC.
Connect everything again and try printing now.
Hope it helps.
Posted on Feb 23, 2012
  • 2072 Answers
SOURCE: Phaser Maintenance Tray Message!
No unfortunatly. That is counted out on a chip with a hard count.
Wish there was.
Posted on Apr 02, 2008
  • 62 Answers
SOURCE: system fault
too many black copies, keep black copies down to 400 at a time and break it up with colour jobs
Posted on Nov 19, 2008
  • 2072 Answers
SOURCE: L6 error keeps popping up
That is a laser error. The motor that drives the mirrors is most likely oing bad, The laser unit will have to be replaced.
Posted on Jan 30, 2009
SOURCE: Xerox phaser 8560n printer. I can ping the
For that go to start menu->control panel->printer and faxes then right click on printer icon click on property then click on ports tab make sure tcp ip port enabled and there is ip address of your printer. Then if still same issue then uninstall old driver and reinstall. Let me know if you need further assistance.Thanks for using FixYa.
Posted on Feb 03, 2011
SOURCE: My Xerox Wokcentre 4260 is
Solution : Perform an On Demand Image Overwrite (ODIO) Image Overwrite Security protects against unauthorized retrieval of confidential data from the machine by removing image data that is left when jobs are processed. When started, all of the physical areas of the hard disks holding job data are overwritten with a series of alphanumeric patterns.
There are two options for On Demand Image Overwrite: Standard and Full Overwrite. Standard ODIO will overwrite all jobs stored in image data as well as fax card image data. Standard ODIO will not overwrite fax mailbox, Poll store (mailbox 0) and dial directory information, or folders created with the Store Job feature, if these features are installed on the machine. Standard overwrite takes about 30 minutes. Full overwrite takes approximately 160 minutes to complete.
NOTE: Full ODIO will overwrite and delete all fax image data, including mailboxes, Poll store and dial directories on the fax card. Full ODIO will also overwrite any images that have been stored in folders created with the Store Job feature. When On Demand Image Overwrite is initiated, the machine is taken offline until the overwrite is completed. Any existing jobs in the queue are terminated, including print, fax and LAN fax jobs.
NOTE: Overwrites can also be performed on a per-job basis, immediately after each job has been processed, using Immediate Image Overwrite. See the Related Items below for additional information.
CAUTION: The machine should not be in Diagnostics mode when the overwrite is started. (The Touch Screen indicates a status of "Diagnostics Mode". This mode is used by Customer Service Representatives when servicing the machine.)
Do not power off the machine while an overwrite is in progress.
To perform an On Demand Image Overwrite from the Control Panel:
  1. Access the Tools screen. See the Related Items below for additional information.
  2. Select [Security Setting].
  3. Select [Image Overwrite Security].
  4. Select [On Demand Image Overwrite].
  5. Select the [Standard / Full Overwrite] button to switch between the two options, and select the required option.
  6. Select [Overwrite Now].
  7. The Overwrite Confirmation screen will be displayed. Select the [Overwrite] button to begin, or select [Cancel] to cancel the On Demand Image Overwrite. The machine will be taken offline and will be unable to receive any incoming jobs. The Image Overwrite will proceed to overwrite all image data on the hard disk.
    NOTE: If Embedded Fax is installed, all Embedded Fax compact flash data will also be overwritten.
  8. When the overwrite is complete, the On Demand Image Overwrite completion screen will be displayed.
  9. Select [Close]. The Disk Overwrite Confirmation Report will print. This details the status and time of the overwrite. The Network Controller will then reboot and network functionality will be unavailable for several minutes.
    When the machine has rebooted, verify that the overwrite operation has completed by viewing the Confirmation Report (under Confirmation Details). The Job Information: Status ESS Disk parameter should read "SUCCESS".
Posted on Jun 08, 2011
Epson printer will not print any copies. I get the message "change cartridges 98/99." I did change both cartidges and can't clear the message and print copies.
i assume that everytime you try to print you get the same message. i sometimes get cartridge unrecognised on my epsom. I have to remove the cartridge, wipe the chip on the cartridge and reinsert.
If this doesnt work please specify printer model and if using original epsom cartridges.
Nov 15, 2011 | Office Equipment & Supplies
I replaced the cartridge of my hp psc 1401, copied the test page that was automatically printed, but now I can't print anything. Copying works OK. I don't get an error message or blinking lights on...
what is the status of print job in the queue? whether it is showing printing or no status in the windows.
if the status is printing you delete all the print jobs and switch off and on .then try print something. if no status is there in the windows then you check whether the printer is off line .try make it online by right click on the printer icon then click on the use printer online.
Aug 10, 2011 | HP PSC 1401 All-In-One Printer
I have a Lexmark 7170. I want to print a document from my computer. Unfortunately, when print is selected, the printer will perform as though it is scanning or copying. How can I get it to perform a print?...
Even though the Mode is on Copy on the Printer it would still print if you send a Job from the Computer!
Since When are you facing this trouble?
Whats the Operating System on this Computer?
Aug 06, 2011 | Lexmark X7170 All-In-One InkJet Printer
When I try to print I get the message " Printer
Check the following steps to fix printer offline error :
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 04, 2011 | Brother MFC-490cw All-In-One Inkjet...
Problem with panasonic dp-2330. i can not print from my laptop. i have the usb cable from my laptop to the printer/copier. i downloaded print driver to my laptop. the laptop recognizes the printer by...
You must enable the USB in service mode F5-88
While holding function key, hold original size ledger key, while holding those two, press the 3 key. This gets you into service mode. Press 5 then the start key. Scroll to #88 and set the value to 2
Apr 27, 2011 | Panasonic WORKiO DP-2330 Copier
Installation was successful but when attempting to print "wirelessly" printer status says printer is offline.
Go to system settings and select the 'Printer' option. Right-click on the printer and enable the 'Use Printer Online' function. Cancel all the printing jobs till that moment and redo the process. Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue. Check all network connections and functions. Be sure the network interfaces work properly. Turn the printer off and on to see whether the device is working properly.
Mar 23, 2011 | Office Equipment & Supplies
Minolta Magicolor 3100 ... Printer sayes its online and ready to print. When i send a print job it spools it ok but when it goes to print it goes offline. I delete the print job and the printer is back...
Does the printer show any message on it's display ?
Most common problem with these printers is the driver setting (mostly media type/weight) conflicting with the settings made via the front panel menu's.
Jan 04, 2011 | Minolta magicolor 3100 Laser Printer
My print job won't print in color. even when I select "color" on the "options" menu of PowerPoint.
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 28, 2010 | HP Officejet 5610 Color All-in-One Printer
I have an HP Photosmart c4180 all-in-one printer. I just tried to install an HP98 cartridge refilled at Office Max. The printer responds with a message: "Cartridge not recognized". There is no...
  • Connectivity :
Oct 26, 2010 | HP Photosmart C4180 All-In-One InkJet...
Error message when trying to copy a document: Paper size detected is not supported. Job cancelled.
  • Connectivity :
Oct 26, 2010 | HP Photosmart 3210 All-In-One InkJet...
Xerox Phaser 8560MFP Laser Printer Logo
206 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
