Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
Blower Wheel install for shop vac WD1665C - Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
How to use Shop Vac 85L450 exhaust as blower
Unlike the old days few vacs today have a blower facility.
In the old days many vacs used a single exhaust port the hose could fit into for blowing and in particular using some of the supplied accessories - such as the famous spray gun loved and hated by everyone in equal measure.
Modern vacs tend to have a diffused exhaust usually through several ports, perhaps because of imagined safety concerns. I suggest you check the operator instructions.
Jun 24, 2014 | Shop Vac Vacuums
Is a shop vac supposed to blow while vacuuming? We've had this for several years and I don't recall it blowing air OUT while I am vacuuming.
You should have two ports on the shopvac. One that is basically your vacuum and one you can use as a blower. Your hose will fit on both connectors. So yes, it would both **** and blow. This is called a "blow-through" system.
Jul 30, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Lost manual for shop-vac ultra 11.5 gallon how do i use the blower
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=shop+vac+ultra+11+5+gallon+Manual
Jim
Nov 29, 2009 | Vacuums
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Motor
Replace the motor... if you live in canada, go to canadian tire or part source they'll have what oyu need to fix it.
Jun 24, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Old red and black Genie Shop Vac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=659916
Posted by girl power on Jun 10, 2008
A Wheel or disk has come off of the motor. I would like to get a copy of the user manual to see if I can determine where it came off of. This Genie Shop Vac was given to us from my father-in-law.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always check with the manufacturer Shop Vac to get an owner’s manual for the older Genie Shop Vac would be @ the Shop Vac Website and or Customer Service of which I will give you @ the bottom of the response. Other wise check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
131 people viewed this question
Top Ridgid Vacuums Experts
Dan
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
