Question about GoVideo VR2940 DVD Recorder/VCR
Recording / no soud
During set up everything checks out, but as soon as I press record the sound of whatever I am recording ceases to come through. When I press stop the recorder does not respond, Even when pushing the power button [remote or unit] the unit will not disengage. The only option is to disconnect the unit from it's power source. At that time it will reset and I can record with sound, most of the time, but I tend to ruin at least one dvd for each one that I am able to record.
  • arthurrtc Oct 27, 2008
    To update the firmwear where do I go and how do I do it ?
  • arthurrtc Oct 28, 2008
    Do you have any other govideo numbers or address' ? 800 736 7679 has been disconnected and the email address can not be found via google. thanks
  • GoVideo Master
  • 19,396 Answers
If there is a firmware download available you can update the firmware, that will fix the problem.
Posted on Oct 27, 2008
  • Ginko
    Ginko Oct 27, 2008
    I checked on the Internet, the firmware is not available for download.
    You need to call the GoVideo customer support phone number, that is listed on the owner manual.
    If you insist that this is a factory defect, they may even offer you a free replacement.
    Find the number on the user manual, call them and ask for a possible replacement or for a firmware update.
  • Ginko
    Ginko Oct 27, 2008
    Here is Go-Video Customer Service Department at (800) 736-7679 or go online tohttp://www.govideo.com to determine the nearest authorized Go-Video service center.
MY PHONE IS RECORDING BUT I'M NOT GETTING ANY SOUND. WHY?
The Microphone maybe damaged, or you may have a bluetooth device linked to the phone during recording, which would have the mic on whatever bluetooth device that was attached (and had a mic) be the recording point. In the event your microphone is damaged, you should find a someone who can replace the microphone on your phone. If there is a bluetooth device connected while your trying to record, you may want to goto control center by swiping your finger up from the bottom of the screen upwards, or go directly to settings / bluetooth, and temporarily disable bluetooth.
Oct 30, 2014 | Apple iPhone 4 Black Smartphone
Poor sound quality from external line
it may be the recorder itself.. these smaller recorders arent known for excellent recording quality..what is it set for..also check the recording lens and clean with a duster spray..it may be dirty..
Jan 19, 2014 | Tascam BB-1000 Portable CD/SD Recorder
Trying to record music from my dj equipment not sure how to connect
out put from the dj stuff to the input lines on the amp your using to record on, once the CD or tape, or whatever your recording onto, is set to record, it should pick it right up , now if your doing all of this off your DJ equipment everything that's used, from record players, to CD to tape, will be run through the main amp your using, if the selection switch is set to whatever, you should be able to just turn on the unit your recording to, and it will pick it up , everything leading to the main amp will be plugged into, a line in, and some, ( tape player ) will also have a line out, ( so should the cd player if its a recordable one, which in turn would be supplying the lines output to each unit .
Jul 25, 2011 | Audio Players & Recorders
During online voice chat my sound is not hearing by my frnds
test your mic with sound recorder in start+Programes+Accessories+Entertainment+Sound Recorder
is it working there or not if it is not there also than you may have problem with your mic or with soud card setting for more information please send your information about your windows+sound card
Jan 26, 2010 | Compaq Presario 700 470024-192 Notebook
I want to disconnect the beep sound when I press record
From the manual:
"When [BEEP SOUND] on the [INITIAL] Sub-Menu on
the [TAPE RECORDING MENU] is set to [ON],
confirmation/alarm beeps are issued as follows.
1 Beep
• When you start recording
• When you switch the [OFF/ON] Switch from [OFF] to
[ON]
2 Beeps
• When you pause recording
2 Beeps 4 times
• If you perform a wrong operation before or during
recording."
Aug 16, 2009 | Panasonic Palmcorder PV-GS9 Mini DV...
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
No sound recording during video recording with olympus fe 170
To my knowledge, an Olympus FE-170 has no audio recording capability and records the video on 15FPS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Olympus FE-170 Digital Camera
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
3000z Zoom in Movies
Lack of zoom during video recording is a "documented feature" of the 3000z. See page 3-2 in the User's Guide: "...you can't change the zoom setting once you start recording."
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
GoVideo VR2940 DVD Recorder/VCR Logo
49 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
