Question about Recoton Advent Advent AV570 Computer Speakers
Speaker keeps blowing fuses
One of the speakers will turn on for a second, then blow the fuse. this has happened three times after it blew initally. these speakers are about ten years old. i dont know much about electrical/speaker repair but the speaker "as is" is completely useless to me so im not afraid to get my hands dirty. thanks in advance
  • 25 Answers
Sounds like a short circuit or a defect inside the circuitry that is allowing more power to flow through, thus blowing the fuse. My advice would be to dispose of these speakers for safety reasons and invest in a good quality set.
Posted on Apr 30, 2008
How do I fix my yamaha receiver? I turned it up and it shut off,tried to turn on heard fuse blow. Replace one of the two fuses 10A 125v that one blew also.
Fuses blow due to an overload. What has happened in you case is one or more of the output devices (found on the big heat sink) has shorted and acting like it was a piece of wire. Now you have to find out which. By the way it might have gone due to bad speaker wires or speakers, or speaker wires touching each other.
Jan 11, 2016 | Yamaha HTR-5890 Receiver
Jbl subwoofer fuse
there is a short in the amp that would need to be fixed before the unit will power on
Dec 12, 2013 | Audio Players & Recorders
Why does a fuse blow in my JVC receiver Model AX-S331?
usually a crossed speaker wire, or overdriving the amp will cause a fuse to blow
Mar 21, 2013 | JVC Audio Players & Recorders
Fuse keep blowing after crossing speaker wires.
Fuses blow when there is an overload. In your case when you crossed the speaker wires you shorted the main amp. This now has a part that is acting just like a strand of wire.
Trace back the channel you crossed the wires and find the main output device(s). Then replace them. They will be located on a heat sink if that helps.
Jul 03, 2017 | Sony MHC-MG510AV Shelf System
Fuse Keeps Blowing
disconnect rca and speaker wires if they still blow you may have a problem with amp
Jan 17, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
My speakers simply will not turn on any more. i was playing music on them and then all of the sudden the power just will not turn on in the sub. Does this mean i blew them out? I didn't really have the...
Maybe. There should be a fuse. It will prolly look like a black knob on the back of the sub. Unscrew it and check the fuse. Replace it with a good fuse.
If it keeps blowing the fuse, the problem is likely in the speaker. If the problem is inside the sub, you may need to repair/ replace the circuit board inside the unit. If you can't get one you will have to replace the speaker as it will keep blowing fuses.
Oct 15, 2009 | Cambridge Soundworks SWBL SoundWorks PC...
Fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Mar 10, 2009 | Dahlquist ORBIT 5.1A System
Z-5300 blown fuse
When fuses blow theres a problem, now how it blows help you find out where the problem is, If the fuse flashes and turns black the second you turn it on or plug it in there is a massive short in the power supply, If it blows but is clear the surge was not a dead short but a overload, Either way best to run it down to the shop and get it looked at
Feb 14, 2008 | Logitech Z-5300e Surround Sound System...
Power Light off & speaker not working
I had the same problem. The screws around the perimeter of the back plate must be unscrewed and the plate must be pried off as it is glued to the box. When replacing my fuse, 2A 5x20 GMA, it blew the fuse again. Disconnecting the second circuit board prevented the next fuse from blowing, but now the question is what is wrong with the circuit board? I cannot see any damage or shorts.
Oct 10, 2007 | Kenwood SW-38HT Subwoofer
The whole system won't turn on
Go to Logitech support and check the faq's on your speakers. You must replace with the same fuse and it may be a 3amp slow blow fuse. If so replace with the same fuse or you will just keep blowing them out.
Jan 11, 2007 | Logitech Z-5300 Computer Speakers
Recoton Advent Advent AV570 Computer Speakers Logo
228 people viewed this question
Top Recoton Advent Audio Players & Recorders Experts
NOEL
NOEL
Tom Chichester
keith klug
Are you a Recoton Advent Audio Player and Recorder Expert? Answer questions, earn points and help others
