Question about Refrigerators
How much $$$ to install an evaperator coil and add freon on a frigidare kegerator model PLKU1267DS?
  • randy nelson
    randy nelson Feb 22, 2012
    i have already ordered the evaperator coil so just the average labor cost to install it
4 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: evaperator coil has gone bad. How much should it
The cost would be $750 + Labour.
You can get a Maximum of 1 year warranty, if you change the Evaporator coil.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 09, 2009
Macmarkus
  • 2605 Answers
SOURCE: where do i add freon on a frigidare frs6lr5eb3. it
Hello, welcome to Fixya. Unfortunately one cannot simply "add freon" to your domestic fridge. Domestic fridges have what is known as a "sealed system" therefore it cannot be charged without opening up the system and rarely needs to be for that reason, hence being labeled "sealed system". If you truley believe it is a leak in the system and needs repair you would need to call in a licensed appliance repair-person to work on a sealed system, most states and provinces it is illegal to work on without a cfc recovery ticket. Thank you for visiting "fixya". Let me know if we can assist you any further. Good luck. macmarkus :)
Posted on Jun 26, 2010
  • 1250 Answers
SOURCE: beverage air dd58 kegerator won't stay cold
the freon system is a sealed system. If you are adding freon, there is a leak. have the leak repaired and this should resolve the issue. Freon should not need filling but one time and only after the leak is located and repaired.
Posted on Jul 11, 2010
The Water is frozen at the back of freezer - model E402B - is there a evaperation pan under the fridge?
Coil freezing is often a symptom of low freon. You might have a pin hole leak, and it's not a DIY job.
Most all refrigerators have a condensation pan, if not you would have noticed a small river, or a rotting floor.
May 08, 2017 | Refrigerators
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
Carrier 38tra inisufficient cooling, frost on outside vapor tube
Recomend changing filter,check to see if blower is blowing and freon.If all is ok clean indoor coil (evaperator coil).
Sep 04, 2010 | Carrier Heating & Cooling
I cannot find the location to add freon to my frigidare uprifgt freezer model number-ffu16f9cw1
Most freezers do not have a tap from the factory to add aditional freon...you will need specialized equipment to be able to do that...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 02, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Model # HTS22GBMBRWW. Appx. 7 years old. Running but the freezer is blowing cool air and does not freeze.
Do you have frost build up on the back wall of the freezer ? If you have a even build up of frost on the back wall in the freezer section then you have a defrost problem.
If you don't have frost build up, and your fan is running as you described. then I would say you have a freon leak. This leak could be anywhere in the seal system, but most comonly will be in the evaperator.
the evaperator on this machine is a litter more dificult to replace and will cost more to have installed than others, The evaperator and the other parts required to install the evaperator will cost about $250 to $350 + Tax and Labor. If the evaperator is bad, I would buy a new machine.
Jan 12, 2010 | Refrigerators
Evaperator coil is freezing up
let it thaw then turn it on if the larger of the 2 interconnecting copper tubes(the insulated one) is very cold then you have a dirty coil or filter. If its not cold then your low on freon.
Sep 21, 2009 | Heating & Cooling
Beverage air dd58 kegerator won't stay cold
The unit is probably low on gas again. If it lasts a month the leak may be difficult to find, as it may be a small leak. Those units don't hold a lot of gas. Have someone do a nitrogen leak check and fix the leak. If no leak is found, have them install a UV dye to help find the leak. :)
Jan 12, 2009 | Beverage-Air DD58 Beverage Cooler
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
