Question about HP DesignJet 500 InkJet Printer
How to center the two print carthridges for replacement?
    Top Expert:
  • HP Master
  • 1,575 Answers
Hi
Turn the printer on.
Open the cartridge access door right above the paper output tray.
The cartridge carriage will move the cartridges into the middle so you can access them.
Good luck.
Posted on Feb 23, 2012
2 Suggested Answers
don_farr
  • 1018 Answers
SOURCE: hp2210 all in one. i put a new ink carthridge in.
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Posted on Dec 14, 2009
I cannot access the exsisting print cartridges to replace them on my hp psc 500 printer
Hi
Please note that the print cartridges can only be accessed when the printer is on.
  • Turn the printer on.
  • To access the cartridges,open the cartridge access door on the front of the printer and right above the paper output tray.
  • The cartridge carriage moves to the center so you can access it.
  • On the top of each cartridge is a latch,lift it.
  • You need to grasp the handle at the top of the cartridge pull forward and lift it up to remove.
Hope it helps.
Feb 22, 2012 | HP PSC 500 All-In-One Printer
Error message:right (color) carthridge missing
Maybe the cartridge is not seated well in the cartridge carrier or just needs cleaning. Follow the instructions on this link to the Lexmark website on How to Clean the Print Cartridge Nozzles and Contacts Manually. If this doesn't help yet your cartridge is a genuine Lexmark cartridge, I suggest you contact Lexmark Technical Support for further assistance. Genuine Lexmark cartridges shouldn't cause you that much trouble.
Jun 09, 2010 | Lexmark X7350 All-In-One InkJet Printer
The other coloring ink work fine except for the black ink. I use the transferable with syringe on it 's carthridge once ;can this clogged the tip end?
Yes clogging can be one of the reason here. You can check this as follows: gently blot the print head on a damp tissue. A good cartridge will leave a full dark band of ink. Your cartridge will likely leave a weak smudge of ink, with perhaps none if you repeat. BTW, on your printer a remanufactured cartridge would show as full even if it is empty. The printer will assume any cartridge it does not recognize must be a new (full) cartridge. Only if after cleaning the head it does not work then please replace the cartridge. Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 17, 2010 | Brother Multi-Function Center MFC-240C...
Hp2210 all in one. i put a new ink carthridge in. it keeps telling to alighn carthridges. i press enter & the printer alighns the carthridge # prints the report. the printer keeps telling me to alighn...
Don
Dec 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Vertical Thick Lines accross papaer on a HP Laserjet 3330
So the "White lines" went away when you replaced the cartridge, and now you have "dark Lines"?
It sounds to me like you have yet another bad cartridge. Is it remanufactured/ compatible?
Although, they can perform very well, they can also be awful depending on the source.
Return it and get another one, or different brand.
Jun 19, 2009 | HP LaserJet 3330 All-In-One Printer
Deskjet HP 6122 Printer carthridge locked.
Reach in with a looong screwdriver and push the white block down.
Mar 01, 2009 | HP DeskJet 6122 InkJet Printer
Kodak 5100 AIO won't print after cartridge change
the red blinking light indicates that your printer wont recognize your ink carthridge. you can try to reseat the carthridge and the printhead. to remove the printhead just press on the release tab which is located on the upper left corner of the printhead wall. If this will not correct the issue, you need to call their technical support hotline. maybe the carthridge is faulty or there is a problem on the printhead. their hotline no is 1 800 421 6699
Jan 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The ink carthridge location
how do I get to the ink cartridge on a hp 5510 all-in one?
Feb 15, 2008 | HP Officejet 5510 All-In-One Thermal...
Hp printer deskjet 920c
My HP deskjet 920c won,t stop blinking, eventhough I have changed the
color and black and white carthridge. It will not print.
Oct 23, 2007 | HP DeskJet 920c InkJet Printer
HP DesignJet 500 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
