Tengo 1 tv polaroid FLM 3232 no enciende unicamente cuando conecto la toma de corriente parpadea 1 sola vez el led azul y ya no hace nada en la fuente de alimentacion interna del televisor se escucha
Mi tv nadamas parpadea 1 sola vez el led azul y ya no hace nada se escucha 1 sividito parpadeante en la fuente de alimentacion interno del tv
4 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
  • 119 Answers
SOURCE: no enciende el lec azul parpadea
Check the power cord for electricity. IF YOU HAVE POWER TO THE TV, IT IS PROBABLY THE POWER SUPPLY.
Posted on Feb 26, 2011
gopakumarg43
  • 75386 Answers
SOURCE: cuando lo conecto a la
¡Hola
¿Cu?l es la marca y modelo de su dispositivo. Sin ella sinformation ¿C?mo se publica una soluci?n para usted? Env?alo detalles que me FixYa. Aceptar.
Posted on Jul 05, 2011
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
Bunas dias , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes...
Que tal yo tambien tengo el mismo problema con mi tv insignia de 32¨ , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes estan presentes a la salida de la fuente, cambie todos los filtros de la fuente pero nada, gracias por su ayuda.
mi corre es carlitoswwway@hotmail.com
Nov 30, 2010 | Insignia IS-LCDTV32 32 in. Television
No enciende si clave y con cable se congela
TENGO UN WALKMAN
NWZ-E438F FRISADO NO HACE NADA QUE HAGO
Apr 04, 2010 | Sony Audio Players & Recorders
LA PANTALLA SE PONE COMPLETAMENTE NEGRA CUANDO ENCIENDO EL AIRE ACONDICIONADO Y SOLO SE ESCUCHA
Dependendiendo donde vivas, y si esto solo ocurre cuando enciendes el aire, es simple que la misma linea que alimenta el aparato de aire acondicioneado, es la misma que esta supliendo energia al TV. El area donde vives debe tener problemas con caidas severas de voltage. Los equipos cuyo consumo de potencia es menor que la inmensa demanda de potencia que requiere un acondicionador de aire, tienden a llevar la peor parte del sunministro electrico. Te recomiendo que busques otro toma corriente para suplir el TV, y para estar seguro de que lo estas colocando en una linea que no esta con el aire, sin encende el aparato de aire acondicionado enciende el TV y ve te a la caseta de breakers, ve bajando (off) uno por uno hasta que veas que el TV se apaga, ponle una matrca a ese breaker ya que es el mismo que suple el aire. Luego conecta el TV a otro tomacorriente y repite el proceso (asegurate tambien de que la nevera esta apagada) si ves que en un breaker diferente al que marcaste hace apagar la tele, entonces dejala en ese toma corriente y con todos los breakers arriba (on) enciende el aire acondicionado) si no sufre la tele, ya resolviste el inconveniente, pero si se vuelve a poner negra, busca un multimetro o tester y asi con el aire funcionando, pon el multimetro en la funcion de voltage AC (voltage alterno) Y mete cada uno de los terminales o puntas del multimetro en un tomacorriente (no hay peligro alguno, el multimetro solo mide) deben haber 120 voltios aproximados con un descenso s ascenso de un 10%, es decir entre 108 a 132 voltios. si baja mucho menos el valor de lo que especifique, entonces tienes un serio problema con la energia que te suministran a tu casa. Si eso ocurre, me escribes y te doy una pequeña solucion a eso...
Dec 29, 2009 | Televison & Video
HOLA NECESITO EL TIEMPO DE UNA ISUZU RODEO 1995 4 CILINDROS. CUANDO LA PRENDO TIENE UN FALLO QUE HACE COMO UNA EXPLOSIONES EN EL MOTOR, Y ASI CORRE. SI TIENEN LA SOLUCION SE LOS VOY A AGRADECER...
Tengo una isuzu rodeo 1995, empezo a encender la luz de check engine y se me apagaba y no queria encender...luego encendio, a veces hace como si no tuviera gasolina pero a veces enciende y se apaga, la utilizo asi pero cuando enciende el check engine se queda sin corriente y se apaga por completo, le lleve a hacerle un chequeo y ni el tecnico encontro nada, me pueden ayudar con ese problema?
Nov 29, 2009 | 1993 Isuzu Amigo
La computadora se traba cuando conecto el cargador de la pila
Tal vez hay un problema con el cargador. Normalmente, usted puede cargar la batería con la computadora. Trate de comprar otro cargador. Pero antes de comprar, probar el cargador de nuevo en primer lugar.
Sep 14, 2009 | Toshiba Satellite R15-S822 Tablet PC
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
