Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Red gun problem phillips 60pp9202/17f
Have started having the red gun distort at random. it will work for about 10 mins and then start flickering a large curved distortion in just the red information. have seen people with problem, but no true repairs/solutions on this site. please advise. thanks for your time and help. please reply at lloydthefourth@hotmail.com
  • rinsurancefl Nov 12, 2008
    Sounds like my issue too except mine happened today for the 1st time and it just stayed that way. The bottom half of the screen looks all messed up and it has to do with the Red alignment. Mine is a 60 inch too.
    Don't know if you got an answer to what the problem might be by now, I'm actually going to call a local shop I got referred to, to hear what they have to say.
Same sort of problem here. My red looks like it's pinched in the middle and is curving inward. The whole picture looks like you should have 3-D glasses. I've heard it's a problem with a convergence chip, but I have no clue how much that will cost to have someone come fix and we live in a rural area in MO. I'm sure that will jack up the price. Mine is only about 4 years old, I wonder how much I could sell it for (as is) and buy a new TV.
Posted on Nov 25, 2008
Polariod tlx-04240b is flickering
There is adjustment to stop the flickering. But, you have to enter its service mode option do do this. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 17, 2014 | Televison & Video
HP Mini 10 my screen randomly starts jumping
The keyboard has a faulty connection to the mainboard. Have it checked in service please
Mar 23, 2013 | HP Mini 1000 Netbook
Our Phillips HD projection tv has lost a picture. It started by blacking out once in a while but now the picture is constantly rolling. The screen is distorted and it's impossible to even recognize what is...
Cloudy,distorted pictures.The tv have R,B,G CRT tubes gun coolant probblem.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced.
Sep 11, 2010 | Philips 55PW9363 55" Rear Projection...
We have a roughly 10 yr old tv that was given to us from friends (therefore we dont have waranty), and it has just started flickering red lines horizontally across the screen. It is a large non-flat rear...
Ur convergence is dead.These problems are colors misalines,3D pictures,colors distorted.U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Feb 16, 2010 | Televison & Video
W2753v screen flicker - refresh
Hi
What causes monitor screen to flicker?
Answer
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Answer
A nearby device can cause stray magnetic fields that will cause the display to be affected.
A problem inside the monitor will cause the display to have problems.
If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
Answer well one major cause can be the weakness of the electron gun that fire electrons on the silicon plate (pixels) that produces image on the screen so there must be some problem in electron gun in my view
Jan 29, 2010 | Computers & Internet
Panasonic PT-61G53W projection picture flickers and distorts
You said it is Distorting, If the distortion looks "3d" or separate red or green or blue images. You may have a bad solder connection on the convergence ic's they are located on a large heat sink the part number on the ic will begin with STK392- ??? there will be two of them and the pins will need re-soldered, or the part will have to be replaced. If you even just solder the pins it is a good idea to check and see if the heat sink compound has hardened it is a white grease between the heat sink and the component, if this has turned hard it needs replaced. If soldering does not fix the problem these ic's could still be bad, and need changed, but before i would do this i would tap on the chassis with the but of my screwdriver to see if the picture flickers. This being done with the set on and many dangerous voltages present. Soldering the chassis of course with the set unplugged.
I don't recommend doing this repair yourself because of the dangers involved with electrical shock even with the tv unplugged.
If you called a serviceman the repair might run around $300.00.
Sep 05, 2009 | Panasonic PT-61G53 61 in. Rear Projection...
KP51ws500 turns green and shuts itslelf off
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
May 02, 2008 | Sony KP-51WS500 51" Rear Projection...
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
Hi
The most likely problem is the auto focus module.
A costly repair.
If you are going to fix it ask for a rebuilt one.
Part# CS00022 R
Feb 29, 2008 | Hitachi 50UX58B 50" Rear Projection...
TV cuts out randomally
Look for over-heated area on PCB==solder bad connects & replace 47m/25v cap in horiz drive circuit.Replace damaged xistors in same area.
Sep 29, 2007 | Philips 32PT9100D 32" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
