Question about Stihl Models 064, 066, Ms640, Ms660
What is the fuel oil mixture for stihl ms660 chainsaw
    Sergeant:
  • 316 Answers
Hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Posted on Feb 23, 2012
5 Suggested Answers
  • 468 Answers
SOURCE: need to know the oil to gas ratio for a 056 stihl
Stihl chainsaws are 1:50 oil to gas ratio. Make sure you use good high-quality 2-stroke oil, preferably that which is made by Stihl.
Posted on May 22, 2010
  • 14 Answers
SOURCE: Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
Posted on May 10, 2010
barterjoe
  • 344 Answers
SOURCE: How do I replace the oil pump on a Stihl MS170
The oil pump is pressed in from the bottom. There is a special bolt and bracket to make sure the pump is set to the right depth. Your local dealer should bea able to get the tool for you but it will be cheaper to have the shop do the work.
PS it is more common on this saw to have a dull chain act like it is not getting enough oil than to have a bad oiler.
I am gold certified and have been doing repairs since before the ms series. I have only replaced two oilers in that time.
Good luck
JOE
www.arcolawn.com
Posted on Feb 11, 2011
barterjoe
  • 344 Answers
SOURCE: How to replace oil pump
The oiler is set in place to a depth premeasured and tough to duplicate without the proper tool. If you use a proper sized bolt 5mm about 200mm long. After threading in till it stops mark the depth with a marker. pull the bolt out and the oiler will be on the end of the bolt.
thread the new oiler on and reverse the procedure.
My recommendation is to see a local service dealer like www.arcolawn.com and purchase the speciality tools:
21 Assembly tool 1123 890 2200 Removing oil pump
22 - Puller 1130 893 1400
23 - Installer 1130 893 1500
After saying all that I would tell you that a dull chain is the number one cause of "oiler problems" because a dull chain will over heat and make it seem as if the chain has no oil.
Good luck
Joe
vote this up if it helped.
Posted on Feb 12, 2011
Will a 56mm cylinder kit fit a 064
http://sawparts.ca/products/stihl-064-066-ms650-ms660-big-bore-cylinder-kit-nikasil-56mm
It seems that YES a 56mm aftermarket cylinder is available for the Stihl 064. Looking at the kit you need to just replace Cylinder, Piston and rings, bearing bush and clips. Worth also replacing the base gasket too.
May 01, 2016 | Stihl Models 064, 066, Ms640, Ms660
Oil leak in tank
There are only a few ways for oil to be leeking
1. Crank housing gasket (most likely culprit)
2, Rubber O-ring on filler cap
3. Rubber seal fitting to Oil pump inlet.
4. Crack in the crank housing
Jan 25, 2013 | Stihl Models 064, 066, Ms640, Ms660
Tension screw won't tighten the chain on a Stihl MS660
remove the cover and look to see if the tab is broken off
Apr 14, 2012 | Stihl Models 064, 066, Ms640, Ms660
Echo chainsaw 16in. model 280 E(P) or 290 EVL(P) \r\nLooking for the correct oil and gas mixture ?
The mixture for most echo products is 50:1 ratio. You can use the Stihl fuel mix in this unit .. The Stihl fuel mix is also a 50:1 ratio.
Mar 29, 2011 | Echo Garden
Fuel mixture for Poulan 245 and 306 chain saw's
245 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/30945e6822106f5388256b3500246efa?OpenDocument
306 here
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9a98d7ae6c77deaf88256b350024ae42?OpenDocument
I use 50:1 in everything.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Jan 26, 2010 | Poulan Garden
McCulloch chain-saw fuel-oil ratio 3200
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
Lou
Nov 07, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What is the fuel mixture for the mcculloch 3216 chain saw?
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 13, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Fuel mixture homelite d3350b
Fuel/Oil Mixture
    Lou
Oct 09, 2009 | Garden
Im trying to find out the mixture ratio of oil to gas for my craftsman 55cc 18 in bar chainsaw
Fuel oil mixture is deturmined by the brand of mixed fuel you use, not the machine. The machine will state what it's recommended oil brand states. Example a stihl chain saw will be 50:1 with stihl oil but if using echo oil it would be 35:1.
Mar 29, 2009 | Saws
Fuel requirements for a Stihl 131 Polesaw with the 4mix engine?
hi Ray
For your polesaw Stihl HT 131 with 4 mix engine you need a fuel/ oil mixture.The lubrication of the engine is realised through the fuel/ oil mixture(you need a superior quality of the oi for the mixture ).Buy it from an authorised Stihl dealer shop.Any other oil is not needed on the 4 mix engine.
best regards savumihai71
Dec 05, 2008 | Garden
Stihl Models 064, 066, Ms640, Ms660 Logo
546 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
