Question about U.S. Robotics MAXg USR5417 802.11g/b Wireless Adapter
Error code 10 Device cannot restart
I try to install my usr5417 at 2 computers, but I always got the same problem... Firstly, I put install cd and begin installing ... I did what it says ... (First, install .. then shutdown ... place card ... power on computer) After windows restarted firstly it found a network controller and installed it as us robotics maxg pci ... But after this it found a pci card and couldn't installed it ... On the other hand, firstly installed network controller (as us robotics maxg pci card) gave error message ... (Error code 10 Device cannot restart) I am certain that pci cards is working... I dont know what to do ... Any suggestions ???
I faced the same problem. In Windows XP it was installed successfully. In Windows 2000, I got the same error. However, I do believe that the problem is not the OS, but the PCI bus. The Windows 2000 system,is quite old, so it may be PCI 2.1 and not PCI 2.2 as required.
Posted on Jan 03, 2007
    President:
  • 2,961 Answers
Generally a code 10 refers to a dead component unfortunately.Although the card will be recognised.
Posted on Oct 10, 2006
Error code 31 CD ROM driver not available how to install this driver
  1. Restart your computer if you haven't done so already.
    There is always the remote possibility that the Code 31 error you're seeing was caused by some temporary issue with Device Manager. If so, a simple reboot might fix the Code 31.
  2. Did you install a device or make a change in Device Manager just before the Code 31 error appeared? If so, it's very possible that the change you made caused the Code 31 error.
    Undo the change if you can, restart your PC, and then check again for the Code 31 error.
    Depending on the changes you made, some solutions might include:
  3. Delete the UpperFilters and LowerFilters registry values. A common cause of Code 31 errors is the corruption of two registry values in the DVD/CD-ROM Drive Class registry key.
    Note: Deleting similar values in the Windows Registry could also be the solution to a Code 31 error that appears on a device other than a DVD or CD drive. The UpperFilters/LowerFilters tutorial linked above will show you exactly what you need to do.
  4. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 31 error is a likely fix for this problem.
  5. Replace the hardware. As a last resort, you might need to replace the hardware that has the Code 31 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you're convinced that hardware isn't the cause of this particular Code 31 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those before you try replacing the hardware, but you may have to give them a shot if you're out of other options.
Applies To
The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Aug 16, 2016 | Computers & Internet
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Jan 23, 2013 | Lenovo Computers & Internet
Hello, my wireless is not showing on my computer and when i go on device manager on my computer it has a question mark on ethernet controller and say erro code 28, how can i fix this?
Do your Wireless Device (PCI or USB unit) comes with an installation CD? If so, use the CD to install the software/drivers.(Instead of using the Windows wizard). Remove any previous installation before reinstalling with the CD.
Resit your device to a different USB port or PCI slot. If the drivers/software are properly installed, windows will detect and installed the device correctly.
Cause of the Code 28 Error (In general)
A Code 28 error is caused by a missing driver for that particular piece of hardware. There are several of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
2.Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
Undo the change, restart your PC, and then check again for the Code 28 error.
•Roll back the driver to the version prior to your update.
•Use System Restore to undo recent Device Manager changes.
3.Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
Important: Make sure you install the drivers for the correct operating system. Example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Most Code 28 errors are caused by updating or install the wrong drivers for a device.
4.Update your OS to latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
**Note: Certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
5.Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. Not recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Hope it helps.
Aug 22, 2010 | Microsoft Windows XP Professional
Dear Sir/Madam, I have a Dell notebook with an Optiarc RW AD-5540A DVD player. Now I have "error code 10" = "the device cannot start". How can this be fixed? I am not computer literate, really. thanks....
An error code 10 error occurs when Device Manager can’t start a hardware device. This error is usually caused by corrupted or outdated drivers, so most often the solution is very easy.
  • The first solution to to restart your machine. Some error messages can be caused by a temporary problem.
  • Next, did you just install a new device or Windows update? If you did, this might have caused the problem. Either roll back the driver you installed, or use the System Restore to undo recent Device Manager changes.
  • The most common fix for a Code 10 error is to uninstall and reinstall your device drivers. If it is a USB device device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall.
  • You might also try to update the drivers for your device, if a more current version is available.
  • You can run an update for the Windows Service Pack. There might be a patch available which will solve your error.
  • If none of the above solved your problem, you should take out your DVD drive and test it in another laptop, if possible, or connect it to a desktop computer using a converter.
  • If all of the above solutions don’t fix it, you might need to replace your DVD drive.
To update the DVD drivers, you have to search your computer manufacturer's website for the drivers. However, here's an easy way:
Use this driver scanning tool, which scans your computer for the needed drivers. It has an option to automatically retrieve them for you.
You can download this free tool from here, or directly from this link.
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
Hope that helps.
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 03, 2010 | ASUS (CD-S520QUIETRACK) Internal 52x...
Sansa clip code 10 error
The solution for a Code 10 error is always to unplug the mp3 player from the computer, uninstall all software related to the hardware (in this case, uninstall all Sansa-related software), restart your computer, reinstall all software from the installation CD (you can also get it from Sandisk's website if you have lost the CD), restart the computer one more time, and THEN replug the mp3 player.
There MIGHT be an easier way - you can try running the Sansa Recovery Tool - but Code 10 is almost universally an uninstall/reinstall situation.
-Tha Mp3 Doctor
Feb 27, 2009 | SanDisk Sansa e260 MP3 Player
Error code 10-FC06-000D while using recovery cd (backup)
Error code 10 XXXXXXX is related to hardware. It is default code generated by device manager when the operating system failed to determine which specific error code to return after an error occurs.
Error code 10 error pertains mainly to hardware issues and to compatibility issues between hardware and the software.
To troubleshoot the code 10, go to control panel>system> device manager and check if any of the hardware display a yellow “!” or a red “stop”.
1). Update the hardware device driver from either Microsoft or device vendor web site.
If the device is preinstalled on the computer, visit the computer manufacturer’s website.
2). Make sure the device is enabled in the computer BIOS. You need the system documentation, if you don’t know how to do it.
3). Disable any advanced feature of the device.
4). Install the most up to date service pack and any other updates.
Oct 29, 2008 | Toshiba Satellite A205-S4617 Notebook
Error Code 47 - Got this message when looking on the system info under problem device? I'm not a technician.... don't understand where and which are the conflicting devices. My CD-DVD Rom doesn't work and...
Hello ,
As per the issue described by you Error Code 47 is described by Microsoft as given below ( as in the link http://support.microsoft.com/kb/310123 ) :
Code 47
Windows cannot use this hardware device because it has been prepared for safe removal, but it has not been removed from the computer. (Code 47) Recommended resolutions
Here are some things that you can try to resolve this problem.
Reconnect the device
This error code occurs only if you used the Safe Removal application to prepare the device for removal, or pressed a physical eject button.
Reconnect the device to your computer
Disconnect this device from the computer, and then connect it again.
Make sure that the device is connected correctly to your computer, and then restart your computer. Click Start, click Shut Down, and then select Restart in the Shut Down Windows dialog box to restart the computer.
If it still does not help then definitely refer the notebook to the HP authorised service centre.
Regards ,
Puloma
Oct 16, 2008 | Computers & Internet
Pioneer DVDRW DVR-K17B ATA Drive
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
Aug 06, 2008 | Pioneer DVR-107D DVD±RW Burner
U.S. Robotics MAXg USR5417 802.11g/b Wireless Adapter Logo
385 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Sunday Ojelabi
Sunday Ojelabi
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
