Question about Samsung LN46B650 46/49.5 in. LCD HDTV
Samsung 1080p lcd tv got wet, now front control panel or remote not working
The screen is working and sometimes I can get it on the ext and I can then watch Sky but it is in demo mode with images down the right hand side. Its not accepting signals from the remote and the panel on the front only works occasionally.
SOURCE: Picture Flashing
I have a similar problem but my picture flashes black and white and the sound goes at the same. Also sometimes it will flash pink and blue. I've read elsewhere that the issue is a known problem with compatability between Samsung tv's and sky boxes. Apparently the box needs to be replaced but I'm unsure what type of box. I've read perhaps a PACE sky box could fix the problem. I think the best option would be to contact Samsung - that's what I'm going to do.
Posted on Apr 01, 2008
SOURCE: weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Posted on Nov 18, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
  • 132 Answers
SOURCE: Samsung LN-R408D - No Picture
That P type fuse is a 3 amp 32v fuse.
http://www.wehong.com/news_editor/UploadFile/20093418384247.pdf
Posted on Oct 09, 2009
tvservice306
  • 458 Answers
SOURCE: Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Posted on Jan 01, 2010
Testimonial: "Thanks for the info! Very helpful!"
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
How to change samsung tv t con board
Ken, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung LED TV Repair Con Board Replacement No Picture on Screen Image...
LCD TV Repair
Troubleshooting Distorted Video Con of LCD Panel TV Repair Vizio Sony...
Mar 22, 2016 | Samsung UN65F6300AFXZA - UN65F6300AF 65...
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
VO37LHDTV10A 37 in Remote malfunctioning
Cheapest route is to get a universal remote and start over. Most remotes have their life span. Sometimes shorter. Any abuse of the remote by dropping, getting wet, etc will make it quit. Hazards of a little piece of equipment we don't see as important UNTIL it does not work!
Mar 06, 2014 | Vizio VO37LHDTV10A 37 in. LCD TV
Remote control deprogrammed
Did you perhaps change the batteries for fresh ones? Take the remote to your electronic store and them to test it. They have a tool that test the codes and frequencies.
Feb 22, 2014 | Samsung Electronics Samsung 40" EH5000...
How do I turn my Dynex 40'' LCD TV 1080P on with out the controller?
Have the remote tested----our shop uses a tester--if remote is bad we usually can fix it for 10 dollars or less.
A digital camera with a LCD display can also be used in a dark room--remote pointed at it and buttons pressed---camera display will flash faintly in response.
Failing that try to locate a replacement remote (good luck with this brand).
May 16, 2012 | Televison & Video
My Samsung LCD 1080P LCD screen is damaged. How do I replace it?
You are better off buying another TV. Screen usualy costs more then a new TV. It is not an easy job. About 2hrs for a decent tech. Screen for a 37" is about $600-700. A sony....$1300 new sony 799. Best is to sell it for parts. You may get $50-100 for it. Sorry for the bad news. Best to put the WI away/or play nice :). Hit by Wi remote 60% of broken screens ,20% P'd off wife/lover, 10% bad football game,8% kids/bird/pet,2% installer error.
Jan 15, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
Samsung 46 '' HDTV 1080P --------no sound
what is the complete model number of your tv?
does the volume control display pop up with a headphone or speaker sound on tv mode?
Mar 20, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
Polaroid tv
As a home theatre sales person, i can say that i have had my fare share of dealings with new TV manufacturers. Although sometimes what i am about to say sounds a little abrasive, it seems as though youve fallen victim to the newly developing 'disposibility' trending in electronics manufacturing. You may have already tried using the on board controls, and if that works, try an advanced learning remote control to regain control of the functions. if the onboard controls arent working either, you could try to send it in for repair if its under warrenty, or look at buying a new flat panel. The avg repair cost on an lcd is 300-600 for parts and labor, there are many 1080p 40-42 in the 600-800 range.
Dec 17, 2008 | Polaroid FLM-4201 42 in. LCD Television
Samsung LN32A550 32-Inch 1080p LCD HDTV
Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!]
Samsung LE32B650T2 32-inch Widescreen Full HD 1080p
Save On "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Dec 10, 2008 | Samsung TXJ2879 28" TV
Samsung LN46B650 46/49.5 in. LCD HDTV Logo
98 people viewed this question
Henry  Thomas
Henry Thomas
