Question about Kenmore Washing Machines
Can i use my washing machine with no lid switch
  • Kenmore Master
  • 2,295 Answers
As long as everything is working it's ok,all it is is a safety switch so the washer won't run with the lid open,a kid could open the lid when it's spinning and it won't shut down and if the kid sticks his or her hand or arm inside it could get ugly so it's a safety switch that's it.
Posted on Feb 22, 2012
dazmaraz
  • 67 Answers
SOURCE: Washing machine lid switch
not sure what machine tou on about,but no switches should be bypassed
Posted on Oct 16, 2007
SOURCE: replacing lid switch on Kenmore 80 series washing machine
It's attached under the top panel but depending on the year of manufacture it could be on the right, below a hole where the strike comes down or on the left rear under the console.
Posted on Jan 07, 2008
AlmostBob
  • 550 Answers
SOURCE: Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Posted on Aug 29, 2008
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
jmgldsmth
  • 1889 Answers
SOURCE: replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
Posted on May 29, 2009
Tip
The washing machine will not spin?
There are many possibilities for this problem, but the most common and regular problem seen is as follows:--
There is a lid switch in the washer. The washing machine will not start spinning till the lid is closed. In some cases it has been seen that lid is closed still the washer does not spin. in this cases the lid switch has to be checked. if the lid switch is faulty then the closed lid will not be detected by the washing machine, and it will not start spin cycle.
This will help. Thanks.
on Mar 18, 2010 | Washing Machines
Spin cycle doesn't work on washing machine
If this is a top loader then check the lid switch. A common failure is the lid switch fails.
Inspect the lid to make sure the plastic component "Lid Switch Actuator" Has not broken off from the lid. The actuator protrudes through the hole identified by the red arrow above and actuates the switch. A quick check is to listen for a distinct click as the lid closes.
No click no spin. With click if switch bad no spin. A qualified technician needs to replace the switch if bad. The lid removes easily of course power must be off by unplugging the washing machine.
Dec 21, 2015 | Washing Machines
Washing machine top loader aqua smart the lid cannot lock while washing. I have tried switching the machine on and off, still won't work. This happened a little while ago but then is rectified i
Is the lid lock tang on the lid ok & not broken.
You need to jam the lid lock lever in the lid lock down for it to do a wash.
This is where your lid lock is
Feb 21, 2013 | Fisher and Paykel GWL11 Top Load Washer
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Lid will not open
It means your lid switch is defective.If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch this videos below.
http://www.repairclinic.com/Washing-Machine-Troubleshooting#repairHelpVideoTabs Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Thanks
Jun 27, 2011 | Washing Machines
My Kenmore 22712 Top load will agitate, but when it switches to the spin cycle I get nothing. The motor wont run and the tub doesn't spin.
open the lid a lttle and close it down a few times,if you don't hear a clicking sound when it closes you have a bad lid switch,or open the lid and stick a screw driver in the hole where the piece on the lid goes down into when the lid is closed, if it doesn't click and the machine doesn't run then the lid switch is bad.,they don't want the machine to run with the lid open when it goes into the spin cycle,if you send the full model number located beneath the lid when it's open on the back panel under the lid.let me know how you make out
Jan 13, 2011 | Kenmore Washing Machines
Water is now filling, washing going round in drum but not rinsing or spinning.
Spinning and Rinsing require a safety switch to be enabled by the closing of the washers lid.
Check around your lid and washer lid opening to find the mechanism that is used to activate the safety switch mounted just under the lid opening inside your machine. Sometimes it is a plastic plunger(protrusion) on the lid that mates with and opening(hole) in the machine around the lid opening to cause this switch to close. Other times it is on the hinge side of the
lid and the protrusion is formed right into the metal of the lid itself to push a plunger on the hinge side to close this safety switch.
Most spinning problems on machines are cause by this lid safety switch. Washing machines cannot spin if the lid is not closed and this safety switch is not working to switch power to the spinning motor.
Aug 30, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Washing machine stops after washing does not rinse and spin
verify lid switch function first. you can bypass lid switch with jumper wire. unit will not spin out if lid is open. if switch goes bad it thinks lid is open when it is actually closed
Jun 24, 2009 | Washing Machines
Can you bypass the lid switch on a roper washing machine?
Oct 15, 2007 | Washing Machines
Washing Machines Logo
114 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
