Question about HP G60 Notebook
HP60 that reads discs as "blank"
I have an HP60 that will not read discs. It asks me what I would like to do with the "blank" disc. When I first bought this laptop last year the same thing occurred after I had it for a few days. I took it back to the store I bought it from and the tech went into the setting somewhere and fixed it. I asked him what he did in case it happened again and he told me not to worry about it, that it wouldn't happen again. Any input would be much appreciated. Thanks!
  • jen_motz
    jen_motz Feb 23, 2012
    It does this with all discs and it will not burn discs either. I know he didn't swap out the drive because he never left the counter or opened anything up. He did it there right in front of me. He fixed it by only using the mouse pad.
    Genius:
  • HP Master
  • 1,274 Answers
Does it do this with all discs or just discs that have been burned? if it's just cd's that have been burned it could be that the writing session wasn't closed properly, if it's all discs then it could be a drive setting. more than likely though, the tech swapped the drive out completely which is why he said 'not to worry about it'
Posted on Feb 23, 2012
  • Friendly PC Repair
    Friendly PC Repair Feb 23, 2012
    alright well here's a couple things you can try. 1. go into device manager (press the windows key + the r key and type devmgmt.msc in the run box) right click your dvd/cd drive and click uninstall. reboot your computer to see if after it reloads the drivers the problem resolves itself. #2. go to the hp support website and download the latest firmware for your cd/dvd drive and flash it. one of those should resolve your issue
Cd drive is scratching discs
I recommend you replace this CD drive rather than trying to fix it.
Feb 25, 2013 | Acer Aspire Computers & Internet
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Disc not formatted
dvd wr problem may be less not read....or try to new blank disk
Aug 08, 2012 | HP Computers & Internet
I am unable to engage the record button, the display reads "unreadable or unrecordable disc"
There are several types of blank discs (CD-R, CD-RW). This unit only handles the CD-R discs. Unfortunately, this particular unit is even fussy about the CD-R discs it does accept. Even more unfortunately, there is no way to determine which will be accepted and which will not work. At this point, I can only advise you to try CD-R discs from a different manufacturer. Read the first review on amazon.com. Same issue I have had. Sorry and good luck.
Jul 24, 2011 | Koss CDR200 2-Disc CD Recorder
Im getting a message that says "this disc requires on-the fly copying" What does that mean?
which burning software are you using
When using the on-the-fly method, insert the original disc into a drive and a recordable disc into the drive. The original disc in the drive is copied immediately without any time delay to the blank disc in the recorder. The on-the-fly method allows you to copy discs very quickly, and does not require any additional space on the disc.
In order to be able to use the on-the-fly method, you will need at least two drives: one for reading the disc and a disc burner for writing. The following requirements apply to the read drive and disc burner:
· The disc burner must feature buffer underrun protection, or the drive must be capable of delivering the data sufficiently quickly. The read speed should be at least twice as fast as the write speed.
· The read drive must be capable of delivering information on the number and type of sessions, otherwise Nero Burning ROM may not be able to produce an exact copy.
If you want to copy Audio CDs, we recommend the copy image method because the quality of the read audio files can suffer depending on the drive.
Hope this helps
Jul 06, 2011 | Toshiba Computers & Internet
Trying to record to disc from VHS After recirding 8 copies, it now reads "Unknown disc, Please check disc" This is a Go-Video VR3845 Unit.
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
My xbox 360 wont read the discs. I've cleaned the discs and have started and stopped the discs numerous times yet it keeps asking to "Open Tray" then "Close Tray" followed be...
I think that your problem isnt that the discs need cleaning but infact the disc reader or the lens needs to be cleaned. try looking at best buy for a lens cleaning kit they are pretty cheap and easy to use hope this helped and good luck.
Jan 04, 2011 | Microsoft Xbox 360 Console
Disc driver not reading discs
Can be several reasons
1. Disk is upside down
2. Lens is durty. Use CD/DVD cleaning disk
3. Disk is recorded in higher speed than your driver can read (for instance reading speed is 16, but disk is recorded on 24).
4. DVD drive is damaged or not connected properly.
Good Luck
Dec 10, 2008 | LG Computers & Internet
First of all I'm running Vista HP SP1. I put a disc (CD or DVD)in either of my LG CD/DVD 20x drives and try to view the disc by clicking on "My Computer" and then the "drive" that...
This could be several things, most likey it's a compat issue with Vista being daffy. Check with the mfg of the drive, see if there are updates for vista or if they should be running on vista. Check with microsoft, see if there are patches for the drive. Also it could just be the drive not master/slaved properly or it could be having mechanical issues.
t
Nov 14, 2008 | Computers & Internet
Disc read error
get it repaired. obviously the drive is not spinning correctly for ps2 disc. so take it to a shop ask for a quote to repair.
most ps2 are about $99.00USD
Jun 07, 2008 | Sony PlayStation 2 (PS2) Console
HP G60 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
