Question about Toshiba Computers & Internet
Dvd recording when i record a dvd on my toshiba laptop with windows vista and try to play it on a dvd player it comes up with disk error. I used a dvd+r disk.
  • 108 Answers
I had the same problem and spent some time looking up this issue. I have a sony dvd player and it seems to have trouble reading almost any burnt dvd or cd. I have read that sonys seem to prefer the cheap dvds and cds for burning. It seems the cheap'O dvd players play burnt dvds and cds better that the nice ones, go figure.
There is more info out there about making sure to burn dvds and cds in the correct format.
You can try different burning software that has more options than just vista.
If you are creating a dvd from a movie file such as an avi or mpeg, please explain more on what you are doing and trying to accomplish.
G'luck
Posted on Oct 27, 2008
HOW do I clear Toshiba DVD recorder error E 4 54040901
You can unplug it from the wall and it should set the dvd player back to factory specs. If there error still comes up, you can try a cleaner disk. If still having issue can switch types of disk. If using + try the - or vive versa. Last thing to try would be the speed. There is S, SL and SLP. Change it and see if will work for you.
Feb 06, 2016 | Toshiba Televison & Video
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
I have a toshiba dvd recorder ( DKR40) and I get a recording error of " Disk not CPRM comp" E-28. what does this mean?
It means that the disk in question doesn't support CPRM- (an encryption system for copy protection - embedded in the source signal that you try to record . CPRM recordings can only be made on DVD-RW discs in VR mode, and can only be played on CPRM-compatible players.
Aug 18, 2010 | Televison & Video
DVD burning problems
try sothink dvd moviemaker software or dvdvideosoft software from www.cnet.com/download.....most dvd recorders will burn (check your manual for the correct type (+ / -) and brand that works best)...but wont let you play on other machines unless you format and the other machine is just as new as the recorder...(our older dvd players will not play these new dvd)
Jun 08, 2010 | LG RC389H DVD/VHS Recorder
Recorded dvd's won't play on other dvd players Toshiba d-r410
You can play these recordings without finalizing them in the D-R410, but if you want them to play
in other DVD players, they need to be finalized. See pages 28 to 32 in manual. If you want to
finalize the disks you've already made, follow the directions on page 32.
Jan 05, 2009 | Toshiba DR410 DVD Recorder
Once we have recorded a show off the tv onto DVD we are unable to play the dvd of the recorded show on different dvd players than the one in which we recorded it off
if you are using dvd+ - R dvd disks you will need to finalize the disks on your recorder once you are done with the recording before it can be played on other players
Jul 03, 2008 | Toshiba Televison & Video
Dvd recording problems
Try emptying your Windows temp Directory, Also you will have problems if you have 512kb memory or less.
Mike @ compurepair.
p.s also invest in some R/W DVDs, this will enable you to try several attempts to get it right, instead of having a bin full of Disks, and a lot of frustration.
Mike @ Compurepair.
Feb 18, 2008 | Acer Aspire 5100 Notebook
Unknown disk error
Did you try using a lens cleaner?
Feb 17, 2008 | Zenith XBR413 DVD Recorder
Toshiba DVR recorder incorrect disk message
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Dec 03, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba RD-XS35 DVD Recorder
Toshiba tech support for this one. If it is not accepting the cleaner disk - you have to wonder if something is already intere or do you mean will not rune the disk? Inwhich case it is a drive failure and needs replacement[of drive if available] or whole machine. Contact Toshiba first though it may be a known issue.
Jul 05, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Computers & Internet Logo
164 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
