Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Problem with Saeco royal digital plus
The machine makes all the process for a coffe, but instead the coffee comes by the coffe outlet it goes to the container for coffee grounds.
Thank tou very much
    Problem Solver:
  • 4 Answers
Try replacing the O ring in the brew unit
Posted on Nov 07, 2008
How to decalcify saeco royal exclusive coffee machine
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Jun 13, 2010 | Saeco Royal Digital Plus Coffee...
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Royal machine ventilate
Open the hot water valve to allow the pump to prime.
Sep 15, 2009 | Saeco Royal Digital Plus Coffee...
Looking for instructions on cleaning and servicing the Saeco Royal
When you clean the brewing unit wash it with hot water, do not
use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied.
Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
To do a descaling:
Saeco descaler is recommended; however, you can use any non-toxic and/or non-harmful descaling product for coffee machines, commonly available in retail stores. The used solution is to be disposed of according to the manufacturer’s
instructions and/or regulations in force in the country of use.
Never use vinegar!
Best regards
Nov 26, 2008 | Saeco Royal Digital Plus Coffee...
Problem machine
Try replacing the O ring in the brew unit part number: NM01.044
Oct 27, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Plus Coffee Maker, Espresso Machine
go into the menu and reduce the amount of water the machine pumps through
Coffee fix
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
Instruction Manual Saeco Royal Digital
I have a instruction manual to this machine.
Best regards
Sep 29, 2008 | Saeco Royal Digital Plus Coffee...
Saeco royal
Try to set the grinder to grind coarser, make 2-3 cup of coffee to get coffee with the new settings.
Aug 25, 2008 | Saeco Royal Digital Plus Coffee...
Saeco royal digital - pressure problem
There can be some calcium in your rapid steam boiler, try to descale the machine and see if it help.
Apr 07, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
157 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
