Question about Panasonic NN-H264 Microwave Oven
Light will not turn off
The under light on my NN-H264 will not turn off. Unplugging for a few minutes does not help. Pad beeps when control pushed but nothing happens. All other controls work. Jarring cowling will brighten light for a second or two. Possible loose connection but that should not effect pad. Pad not over-enthusiastically cleaned.
  • kjamer Feb 27, 2009
    Approx 2 weeks ago, the light bulbs for the range hood burnt out. The MW is 3.5 years old, I figured this was an acceptable bulb life. Removed the bulb to find a replacement. Could not find a 30w replacement, put in a 20 w until I could find the exact match. Since then thethe light never goes off. I have tried the unplug it for a while solution mentioned elsewhere to no avail. My solution was to remove the bulbs, which isn't ideal.
Fdghfd f hf
Posted on Oct 27, 2008
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
One of my microwave light under the microwave are blowing off with a big flash. The microwave still working after that, but the other light still on when I press the button to turning off. I decide to...
If your model is NN-P295SF, then the service manual is here.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line.
Sometimes you get lucky and only a fuse blows, but either can cause a failure on the controller.
We often see this problem on the control panel, which we regularly repair by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jun 29, 2011 | Panasonic NN-P295SF Microwave Oven
Replaced over the stovetop light bulb and now the light will not turn off. Everything else works perfectly.. Why???It is a Panasonic and I see this has happened many times....thank you
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Nov 11, 2010 | Panasonic NN-P295SF Microwave Oven
I replaced both of the oven top/night lights when one of them burned out. Now the lights will not turn off. All other functions work...even the push button switch. What's up with that?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 with a one year guarantee.
Oct 16, 2010 | Panasonic NN-P295SF Microwave Oven
Countertop light will not go off on Panasonic NN-P294SF
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 07, 2009 | Panasonic NN-P294SF Microwave Oven
Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Jan 23, 2009 | Panasonic NN-P295SF Microwave Oven
Glass plate and int light failed - is this a fuse fail ?
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Dec 06, 2008 | Panasonic NN-S753 Microwave Oven
Panasonic microwave oven
Microwave fuses are normally located either on a filter board near where the power cord comes in, behind the control panel between the door switches, or behind the control panel in a hodler, sometimes on the floor of the chassis.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find an authorized Panasonic servicer here.
You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Nov 04, 2008 | Panasonic NN-H264 Microwave Oven
Panasonic NN-H264SF now requires holding a control panael to operate
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Apr 28, 2008 | Panasonic NN-H264 Microwave Oven
Panasonic NN-H264 Microwave Oven Logo
277 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
