DVD won't read in DVD player
    Problem Solver:
  • 5 Answers
If it is scratched try putting toothpaste on them
Posted on Feb 22, 2012
3 Suggested Answers
dcramer531
  • 1654 Answers
SOURCE: My dvd player won't read
The laser is either dirty, or out of alignment or possibly too weak to read the disc. Try one of the laser cleaning disck with an alignment check I believe that maxell sells these, if you can't find one then a repair technician can adjust or clean i, but if the laser is no good then it will need replaced. Might be better to replace the unit before having a tech work on it or your costs will exceed a new unit.
Posted on May 19, 2011
caroldon
  • 17130 Answers
SOURCE: My DVD player won't read, keeps saying disk error
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Posted on Jul 12, 2011
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
Dvd says reading and won't eject
the motor charge belt it's too loose need to change it
Oct 03, 2012 | JVC DR-MV150B DVD Recorder/VCR
Does not spin dvd
Sometimes the brushless motor driver circuit fails. Rarely does the motor itself go bad. On some models, if the the laser diode is too weak to read the disc, the player will not bother to spin it. It won't spin so a lens cleaner disc won't work You can try to take it apart and clean the tiny lens. Don't use alcohol. Windex and a Q-tip works great to remove grease and dirt. Don't buff it hard. Just wipe lightly a few times and look at it at an angle to make sure it is shiny, not hazy. Almost all of these are not an economically viable repair. If cleaning the lens does not help, you are looking at another portable player.
Sep 02, 2012 | kawasaki PVS-10921 Portable DVD Player
The DVD player won't read the DVD. Can I purchase a new eye for the unit?
try cleaning the optical lens of the player.you can use a cd cleaner it is available at electronics shops.or you can maually clean the lens by opening the cover and wipe the lens with a cotton buds moistened with an rubbing alcohol
Jun 27, 2012 | Insignia Televison & Video
My dvd gaves me a bad disc
when you play nothing but bootlegs in a dvd player, they tend to burn out the eye inside the player to where it will only read bootlegs. the original movies capabilities won't work anymore. hope this is a help to you my friend.
Jun 21, 2012 | Cyberhome CH-DVD 300 DVD Player
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
Televison & Video Logo
262 people viewed this question
Top Televison & Video Experts
