Roll Laminator Tahsin/HIC/HOP TCC-2700 27" Instruction Manual
3 Suggested Answers
SOURCE: ibico 2700 wide roll laminator
Mechanic service code number
Posted on Feb 12, 2008
SOURCE: ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Posted on May 29, 2008
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Laminator squeals
The paper is fed into the laminator by rollers usually a top and bottom, one of them is usually made of silicone(rubber) check to see if tose rollers are turning, you may have to pull some covers off to see the rollers, but usually you can look in the throat where the paper is fed in and see these rollers with a flashlite. Not sure of the brand, big or small laminator, good luck. If rollers are not turning, some are belt driven, some are motor driven, could even be a control board or switch.
Sep 24, 2013 | ACCO HeatSeal Ultima 65 Roll Laminator...
The front rollers on the laminator will manually move but will not roll when motor is turned on.
look at the transmission chain between the motor and the rollers maybe it is broken.
Sep 10, 2013 | Ledco Compass 27" Roll Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
Can you tell me how to thread a Graphic III laminator?
5-2 THREADING the LAMINATOR
1. Remove the supply roll mandrels and the feed tray. The supply roll mandrels are now ready to accept
loading of the film rolls, wound with the polyester (shiny) side out. When viewed from the front of the
machine, the core grippers on both the top and bottom supply roll mandrels should point toward the
heat shoes (and toward each other). The tension control knobs should be positioned on the right. Notice the
knobs are labeled "Top Right" and "Bottom Right". If you have rolls of film on which the material is wound
in the opposite direction (adhesive or dull side out) exchange the top and bottom supply roll mandrels so
the core gripper positions are reversed.
2. Slide a roll of film onto the top supply roll mandrel, turning the roll slightly to slide the gripper inside the
core. Center the roll. Make sure the dull side of the film is facing up and the shiny side is facing the
heat shoes during the threading. Scored marks on the supply roll mandrels provide a guide for proper
alignment of the two rolls of film to each other.
NOTE: The pointed metal pieces protruding from the body of the supply roll mandrels grip the cardboard core of the film supply roll to prevent slippage. When placing a roll of film on the mandrel, twist the film supply roll to
accommodate easier film loading.
3. With the roll aligned with the scored line on the right side of the mandrel, place it in the top bracket.
Place the left side of the shaft in its slot first then place the right side of the shaft in its slot, turning it as
needed. FOLLOW THE RECOMMENDED LOADING PROCEDURES CAREFULLY WHEN THREADING
FILM IN THE LAMINATOR. ACCURATE ALIGNMENT OF ROLLS WILL MINIMIZE WASTE AND HELP KEEP
THE LAMINATOR CLEAN.
4. While the machine is still cold, review the threading diagram. With the bottom roll of film centered on
the mandrel and the shiny side facing down, run the film under the bottom idler bar and pull towards
you.
5. Load and thread the top roll of film in the same manner as the bottom roll. Refer to the threading diagram. The
film should run under the silver stabilizer bar and over the front of the top heat shoe. Remember, the shiny
side of the film must always go against the shoe. The dull (adhesive) side must face away from the shoe.
Make sure the two rolls are aligned with each other before going to the next step.
6. Turn machine on and heat to the desired temperature.
7. With both rolls threaded and installed in their respective brackets, unwind enough film from the top roll
to reach the bottom of the bottom heat shoe. Next, unwind enough film from the bottom roll to reach the
top of the top heat shoe.
8. Now drape the film from the bottom roll against the film from the top roll on the top shoe. If the laminator is
hot, the exposed adhesive on the top web will hold the bottom web and make it easy to stick the two rolls
together. If you are threading the machine while it is cold, use tape to stick the bottom web against the top
web.
9. Tip the safety shield down into the laminating position. With the film draped over the two heat shoes, push
one edge of the threading card between the heat shoes so that the film is firmly positioned against the
laminating rollers. If a threading card is not available, any piece of card stock or poster board will work.
10. Make sure there is still enough slack in the web. Turn the drive switch to FORWARD, permitting the film and
feed board to pass through both sets of rubber rollers. Carefully monitor initial threading to be sure the web
reaches and passes through the pull (back) rollers. When the threading card has cleared the back of the
machine, move the drive switch to the center position (off). Whenever you want to remove the film and/or
laminated material from the back of the machine, use the zippy cutting tool provided with the laminator.
11. Slide the feed tray into position.
12. If the machine has the slitter option, make sure the slitters are disengaged (blades in the raise
position) and moved all the way to either side of the machine.
CAUTION: The laminator is designed to be run with the operator directly facing the
control panel and feed tray, not at an angle or from the side of the machine. For
operator safety, the safety shield must be in position over the upper heat shoe
when the machine is ON, or when the drive switch is in the forward position.
Dec 21, 2010 | Office Equipment & Supplies
I need to find instructions for a Hamilton Beach Laminator 2
Hi Rhonda :
Check for manual here please : Hamilton Beach Laminator 2 manual .
I hope that will help .
rate please !
Mar 28, 2010 | Office Equipment & Supplies
I have an office roll laminator GMP 650HRP. I
the increasing and lowering heat on the rollers and increasing and lowering pressure on the pressure stick depend on the thickness of the laminating pouch 120 mic need less heat then the 240 mic.
Mar 21, 2010 | Office Equipment & Supplies
Laminator, how to use!
try going to the manufacturer's website, or reading the instruction manual for your printer. There should be pictures and detailed explanations in there.
~hope this helps !
Dec 13, 2008 | Xerox Phaser 8500/DN Printer
Ibico 2700 laminator
Apr 24, 2008 | Office Equipment & Supplies
547 people viewed this question
jasbo
jasbo
