Question about Exercise & Fitness
Need instruction manual for athlon simplicity lx treadmill
Don't remember how to program it. Have had several surgeries and have not used treadmill in a while. Can't find the guide that came with it.
ercupa190
  • 12223 Answers
SOURCE: I am looking for the instruction & care manual for
Dear Sir:
I will help you inmediately.
Please contact the follow link:
http://www.fitnessrepairparts.com
They will charge for the instruction and care manual.
Thank you in advance, and go get it. blessing. sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Sep 13, 2011
ercupa190
  • 12223 Answers
SOURCE: Buttons don't always want to work
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optical Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
See the diagram for 1/8" or 3mms aprox. and clean up very well.
Attached is a Block Diagram for purpose to teaching people like you,that I did to show how the Main Controller has aprox 90% of functions of the treadmills.
You must clean the keypads with contact cleaner (spray radio schack or computer store) and then tighten the flexible cable to Display Board and then Connector from Display Board vs. Lower Boar( Main Controller Board) very well.
Good luck,sincerely.
E.CUADRA
Posted on Nov 25, 2011
jas247
  • 844 Answers
SOURCE: The walking belt on my
Welcome to FixYa.
Thank you for using FixYa.
Have a great day.
Jas247
Posted on Jun 06, 2011
  • 2418 Answers
SOURCE: I have a Tasco #707
I can not find a manual for that scope. You can try and contact Tasco directly, at 9200 Cody, Overland Park, KS 66214 ' (800) 221-9035
Posted on Jul 17, 2011
  • 6277 Answers
SOURCE: I don't know to use.
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual, parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 14, 2011
I have got E06 error in Lifespan Treadmill.
I have read that the speed sensor near the front flying wheel connected the front roller, sometimes get malfunction. I have just tapped it gently with a screwdriver and this seems to have done the trick. Hope this will help somebody with a similar situation.
Else
Call Vision Fitness Customer Service, they'll help you reset the treadmill by using the console. This will help clear the problem. I've been told that this error occurs when the incline controls are not used often. I've cleared the error using their instructions but after several months it does reoccur. And no I don't use the incline option often so that might explain it
Oct 01, 2012 | Lifespan Exercise & Fitness
Use 1 step automatic buttonhole on simplicity quilters choice
if your sewing machine has a button hole lever, then the button hole
function will not work until the lever is pulled down.
it to the right of needle
I'm including a link for a manual hard copy or download, they cost
different prices
http://www.sewingpartsonline.com/instruction-manual-simplicity-sw240.aspx
http://www.sewingpartsonline.com/instruction-manual-simplicity-quilter-s-classic-sw240-download.aspx
Sep 07, 2012 | Simplicity Quilter's Classic SW240...
Free owers manual
your question is put under the sewing machine name of
simplicity denim star sw210, so that is the links I'm going to supply
for a manual,, but the manual is not free, I don't know where you can
get one for free
http://www.sewingpartsonline.com/instruction-manual-simplicity-sw210.aspx
http://www.sewingpartsonline.com/instruction-manual-simplicity-denim-star-sw210-download.aspx
Aug 06, 2012 | Simplicity Denim Star SW210
I need a free manual for my Simplicity Serger SL350
I can't find one for free, but sewingpartsonline.com show they have
one,, hardcopy or download.
I don't know if the link will work or not, if the link doens't work
go to sewingpartsonline.com
to go shop by catagory
instruction manuals
simplicity & then look for the model number sl350
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl350.aspx
Jul 10, 2012 | Sewing Machines
Need an operating manual for Simplicity, Model SW210
Sorry Angela, been looking for a manual for my Simplicity too but can't locate one either. If we don't contact manufacture for one, we may not get one. Unless someone out there has one to scan and share? Come on folks, help out!
Nov 18, 2011 | Simplicity Denim Star SW210
I do not need an expert, the instruction sheet got wet, so I cannot read it for utiltech self adj. wall timer.
You are asking for a Utilitec manual but don't specify which manual that fixya expert should provide free of charge, which is why you don't need an expert?
Open following link for several different Utilitec timer manuals.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Jun 30, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Exercise & Fitness Logo
284 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
