Question about Apple iPhone 3GS Black (16 GB)
Can,t pair my bluetooth on my iphone3gs ?? - Apple iPhone 3GS Black (16 GB)
Bluetooth pairing codes
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
Oct 06, 2012 | Radio Communications
Moterola wireless headphones not working with my iphone3g
i have the same problem, at the beginning they used to change the songs from my itouch but now the others work but the ones to change tracks. did u get any answers?
May 11, 2010 | Motorola Mobility S9 Headphones
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
Oct 25, 2009 | Apple iPhone 3G
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Set up with iphone3g
1.: Power on your iPhone 3G (if you have not already done so)
2.: Slide to unlock your iPhone 3G (if you have not already done so)
3.: Tap "Settings"
4.: Tap "General"
5.: Tap "Bluetooth"
6.: Make sure Bluetooth is enabled, by setting the toggle to "ON"
7.: Make sure your headset is discoverable
8.: When it shows up on your iPhone, tap it
9.: If prompted for a passcode, enter "0000" (if the headset instructions list a different passcode, use it instead of "0000")
Your headset should now be paired.
Sep 09, 2009 | SouthWing SA505 Bluetooth Headset
No bluetooth connection iPhone
Do u know the version of your computer's bluetooth. because it could be that the i phone has a newer bluetooth version
Jul 07, 2009 | Apple iPhone 3G
Pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Jun 27, 2009 | Apple Cell Phones
Pairing problem for Supertooth btslbc3
-----How to Create a new Connection----
Pairing with Phone
1. Turn off all devices (ST Light and Phone)
2. Turn on Phone
3. Goto Bluetooth menu on the phone (might be in connectivity)
4. Go to device list or paired devices (make sure bluetooth is turned on)
5. Delete any old profiles that are still in there.
6. Goto the Supertooth Light (BlueAnt)
7. Hold down the green button (send button)
8. while holding it down, open the microphone
9. the light should start to flash "red" and "blue" (you can release the green button)
10. go back to your phone, and go into either 'device list' menu or 'paired devices' menu on your phone.
11. click on either search, add or new devices. Function depends on different phones
12. when the phone has found the device, it should say 'ST Light BA V1'
13. select it, then enter passkey "0000"
14. If your phone ask for authorization or auto connect, just click "yes"
Nov 19, 2008 | LG HBM-730 Wireless Headset
Apple iPhone 3GS Black (16 GB) Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
