Question about SiPix StyleCam Blink II Digital Camera
I push the shutter button to take a picture it beeps and doesnt take the picture. this started afteri put a new battery in. what do i do
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
There is a 1 or 2 second delay between when I press the button to take a picture and when the picture actually takes. I put new batteries in the camera, but that did not help.
That's called "shutter lag". You need to press the shutter button half-way and allow the camera to lock in the focus (it will beep) and then press the rest of the way for an "instant" picture.
Jan 13, 2011 | Cameras
Unit has been installed for 2 weeks with a new battery when installed. Came home today, it was beeping. I pushed the middle button but it still keeps beeping.
new batteries are probably dying-- new doesnt mean they cant be faulty install new batteries and observe if problem returns quickly
Feb 04, 2010 | Kidde Nighthawk Combo Gas/co Detector
I push on the shutter button and nothing happens!
Have you tried to put new batteries in it sometimes when they start to die then not all of the functions will work and also cheap batteries can be brand new but not strong enough to run the functions
May 25, 2009 | Kodak Easyshare Z812-IS Digital Zoom...
Can't take pictures
I'm not sure whether this will help solve your problem, in my Canon digicam I have to press and hold the button atleast for a second, till I hear a click.
Dec 17, 2008 | Philips PJ44416 Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Largan chameleon
With the camera on, push the mode button 5 times. The window will show a square with a dark circle in it, and a diagonal line through. Hold the shutter button (that you take a picture with) down until the camera "beeps". This will erase all the pics in the camera. To erase the last pic taken, push the mode button 4 times. This gives you a square with a lighter circle and diagonal line - hold the shutter button until it beeps.
May 18, 2008 | Largan Chameleon Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Shutter delay
If you have installed optional expanded memory, you may notice a delay between the time you press the shutter button and when the camera beeps. You can reduce this delay by pressing the button down halfway, holding it as long as necessary, and then pressing it down the rest of the way when you are ready to take the picture. The reason for this two-step shutter is to save battery power. After a picture is taken, compressed, and written to memory, the Sparc CPU shuts down to save the battery's power. When the shutter button is pressed halfway, the Sparc wakes up and stays in the ready state until the user presses the shutter button the rest of the way. Besides the delay in waking the Sparc, there is a variable delay which occurs prior to the Sparc being in the ready state. This delay is dependent on the amount of free flash memory.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
SiPix StyleCam Blink II Digital Camera Logo
22 people viewed this question
Top SiPix Cameras Experts
Tony
IT Solution
IT Solution
Are you a SiPix Camera Expert? Answer questions, earn points and help others
