Question about Dell Vostro 200 PC Desktop
Dell vostro 200 2 beeps - Dell Vostro 200 PC Desktop
4 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: dell vostro 200 4 repeated beeps on start up
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Oct 05, 2009
  • 644 Answers
SOURCE: Is the Dell Vostro 200 wireless enabled?
Most desktop pc's dont come with any wireless adapters, so i think yes youll need to purchase a wireless card.
Posted on Jan 22, 2010
tweekygeeky
  • 13 Answers
SOURCE: dell vostro 200 4 beeps then with f2 starts
here is the explanation of what can be possibly wrong,
1 long, 2 short - Video adapter error: Bad or improperly seated video card
Repeating beeps Memory error: Bad or improperly seated RAM
1 long, 3 short-Bad video RAM or video card not present
4 short Keyboard communication failure: Bad keyboard controller or keyboard
This is what the typical explanation is. To avoid assumption, i will need info on *********** board...thanks,
Posted on Mar 19, 2010
Why does my Dell Vostro 200 keep beeping?
Defective memory can cause blue screens, no video, beeping sounds. It's possible that you have a defective memory stick.
May 24, 2012 | Dell Vostro 200 PC Desktop
Vostro 200 four beeps at startup then repeats; fan stays on.
Cant say for sure what the problem is, but most probably it is due to a bad RAM module. Try removing it and after removing the dust on the RAM and its slot Re-insert it. Also try cleaning up other areas with a blower too. It should workout.
May 28, 2010 | Dell Vostro 200 PC Desktop
Dell vostro 200 4 beeps then with f2 starts
Mar 19, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
Jan 22, 2010 | Dell Vostro 200 PC Desktop
Vostro 200 won't go to startup
The 4 beeps suggests a memory issue. If you open the case and pop the memory modules out and then reinsert them it may clear the problem. One way to check if an individual memory stick is bad is to reboot as you put them in one by one.
I hope this helps.
Jan 03, 2010 | Dell Vostro 200 PC Desktop
Dell vostro 200 4 repeated beeps on start up
Beep codes Pc
More beep codes
Oct 05, 2009 | Dell Vostro 200 PC Desktop
4 short beeps on vostro 200 monitor shows black?
http://support.dell.com/support/edocs/systems/vos200/en/index.htm
the above link will allow you to download pdf versions or view HTML versions of the Dell manuals for your machine.
4 beeps is RAM read/write failure
if you recently installed new RAM (memory) you should check to be sure that it is compatible. If not, you might just have a loose memory stick.
just remove and re-install memory modules making certain to seat them firmly.
!!!! Very important ..before touching memory.. be sure to discharge any static from your body - by touching anything grounded (I usually leave my tower plugged into a grounded outlet and make sure the rocker switch to the for the power supply(the switch on the back of the computer) is turned off.
Aug 09, 2009 | Dell Vostro 200 PC Desktop
Won't boot..getting 2 short beep codes..have tried memory that i know is good.
Its the problem with the memory only. the memory u get from dell will noit suite ur pc. try changing the same type and speed memory
Apr 20, 2009 | Dell Vostro 200 PC Desktop
Dell Vostro 200 PC Desktop Logo
501 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
