Question about Saws
Carbon brush has broken and is stuck in so i cannot put a new one in, on Einhell sliding mitre saw
The saw started spluttering then stopped, one carbon brush had broken up and the other is stuck in, the spring and wire have detached and i cannot get the carbon bit out
  • Anonymous Mar 14, 2014
    makita grinder carbon brush stuck
  • 885 Answers
If you cannot get the carbon pieces and/or spring out of the brush holder your only option is to take the saw apart and remove the armature. From there you can either push the carbon piece(s) through or out from the other side. It will also give you a better assessment of any damage caused to the brush holder and armature contacts.
Posted on Feb 27, 2012
Testimonial: "Thanks, I have taken the saw apart and pushed through the broken carbon brush. Thanks for the advice"
thabrain
  • 76 Answers
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Posted on Oct 28, 2008
rowdy45176
  • 2176 Answers
SOURCE: My Ryobi 10 inch miter saw, model TS 1340 has been
It sounds like the armature has developed an open commutator bar. What did the brushes look like that you took out. But before I assume the worst I would unplug the tool and remove both brushes and with a flas light look into the brush tube while slowly rotating the armature looking for a discoloration or raised bar. If not you might bet by with cleaning the commutator with a special stone for this, you might be able to get one at the repair shop where you bought the brushes. If you want to send me the photo of the arcing it might help on my end. Let me know
Posted on Mar 09, 2009
efs_perpends
  • 1996 Answers
SOURCE: I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Posted on Apr 10, 2009
SOURCE: ryobi compound mitre saw sliding 10
rotating the laser in its' housing moves it left and right. The hexagonal bolt on the sides needs to be loosened to do this, then it can also be adjusted up and down. Make sure the trigger to the saw is locked before doing this.
Posted on May 08, 2009
  • 8404 Answers
SOURCE: Compound mitre saw won't shut off unlss unplugged
Relace the switch.
I am presuming the lock button has not been inadvertently pressed ... Check that first.
The condition you deacrive is dangerous. Please fix it before you use it any more.
If you require additional assistance, let me know.
Otherwise, check RepairClonic.com for parts and technnical instruction from their crack crew.
Thanks for the opportunity to lend you a hand
a
Posted on Sep 26, 2009
Saw won't start when you hit the starter switch
Auto stop in one of the 2 carbon brushes is activated ,, a broken power cable or a loose contact on the switch
Dec 17, 2015 | Saws
My recon 2500 chop saw stopped working .power to switch and up to capasiter but nothing after
The capacitor is only for Radio interference suppression on the switch this kind of machines has no induction motor but with carbon brushes ,
Electronic modul , carbon brush auto protect Switch start-up delay where could be a 8 ohm resistor is the capacitor that you mean it is is a white colored with 2 black caps thats a start up resistor to get the peak of voltage out to start up.
But a broken collector on the armature , sound resaistance check the armature place the multimeter on the both carbon brushes so that you have sound (thats must be given) and turn slow the sawblade by hand if its stops then there is a bad (or) collector(s) on the armature. Always check the powercable under some tensile force because if there is electronic modul and it was started it will fast stopped if there is a
cable break
Dec 07, 2015 | Saws
Rts21 table saw will not run, was running and just quit?
auto stop protect in carbon brush little spring that pushed one of the carbon brushes of the collectors replace carbon brushes is the most likely if it has it working hours on it.
Only if it has no induction motor. or powercable broken ? on pull relief sometimes .
Sep 05, 2014 | Saws
How to replace brushes when they will not come out normally?
I had the same issue. Turns out the brushes were fused into the brush mounts. I pulled on the copper end cap and wire only to break it off at the carbon brush end. I had to pull the motor out of the housing (stator) to expose the brushes. I then used a tool to push the carbon brushes back in and out of the brush mount assembly. You could also push from the outside in, just make sure you get all the carbon pieces and use a tool that won't put scratches in your brush housings. My brushes where well over 1/2 inch long....but they were just fused into the assembly, so the spring wasn't pushing it properly against the commutator, which I am guessing was the reason my saw just stopped in mid use....I had ripped a straight line in a board and stopped for a few seconds to reposition the saw only to find it no longer worked.
Apr 28, 2014 | Makita 7 1/4" Circular Saw 5007NB
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
How to replace carbon brushes for Hitachi C7U2
It sounds like they have become stuck due to non use. All you can do is try to pull them out. If they break, clean out the brush holders before you fit the new ones. Also check the armature is ok first.
Feb 12, 2014 | Hitachi C7u2 190Mm 110V Circular Saw
brushes can get jammed in the holders if not used for a while. If you can not pull them out then you will have to cut the wire in the middle of the spring, remove the main body from the aluminium casing and push them through. Then replace them with a new set after cleaning the holders so the new ones slide in and out smoothly.
My saw will cut for 5 seconds and then the blade stops spinning. When I back the blade out it starts again and the process is repeated. It takes a long time to cut wood this way. What's the problem? Is...
I would suspect a combination of the two! You blade probably isn't sharp and your saws brushes are probably getting worn. The brushes are made of carbon and are pushed up against the rotor by a spring. As the brush wears down the spring doesn't put as much pressure on the brushes which means it will stop working when placed under heavy load.
Aug 11, 2011 | Rotary Professional Grade 7.25 Inch...
The switch of the saw is not working 00
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
Jun 28, 2010 | Remington 16" Electric Chain Saw
My Delta band saw motor is having issues. I was
I would bet it's the Motor Brushes.They are locaded on the housing of the saw, accesed by unscrewing the plug.The brushes are replaceable and your saw will be fixed.Where to buy replacents could be an issue,Check manufacturer or search power tool replacement motor brushes.If stuck you can try to unscrew the plug the brush is at the bottom engaging the motor armerure,there shoud be a spring keeping contact.Inspect brush condition it looks like a carbon block worn to the curve of the motor.Go online do a search on how electric motors work you'll see exactly what I'm explaining.Cheap part easy fix.Good Luck.
Sep 05, 2009 | Saws
Saws Logo
536 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
