Question about ScanSoft OmniPage Pro Office 12.0 for PC
It will scan the first two pages but the remaing pages will be blacked out. I tested the scanner with another program and it can scan all of the pages so I just need to know what I need to do to fix the program
In lg tv using cp 79a chassis eax35112303(4)picture comes only top on the portion aproxemately 4" remaining portion of the crt blank
Check and replace the vertical scan output IC. Check the vertical scan winding of the deflection yoke for open circuit.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 17, 2015 | LG Televison & Video
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
Scan and copy produce a black page
Scan head faulty(which is moving while scanning & copying) , replace it..
Nov 16, 2011 | HP Officejet 6500 Wireless All-in-One...
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
I scanned a 17 page document to pdf and got a 15mg file which I could not sent by e-mail. Checking some other pdf files, I see a 47 page document that is only 5kb. What's the deal? BwO
Resolution you scanned it at as well as scanning in color versus black and white. Also, that 47 page document might be vector graphics and text rather than bitmap information.
Scan in 200dpi black and white to get a usable (readable) and small file. Should be about 100-200kbytes per page.
More info on scanning: http://en.wikipedia.org/wiki/Image_scanner
-=/ Daft Tech /=-
Oct 23, 2009 | HP Officejet 6500 Wireless All-in-One...
When I scan the pages it has a black line..
Try to peek into the scanner while scanning, you probably have a burned out LED element.
Oct 13, 2009 | Panasonic KV S2026C Path-Through Scanner
Outlet ground problem
3-4 prong green is simply an additional grounding wire, red and black are hot leads, white remaing (nuetral) nad the green (ground " line gets hooked directly to cabinet
Feb 12, 2009 | Speed Queen AES28AWF Electric Dryer
Brother Scanner, scans the page but prints black and vertical
I called technical support for this issue previously with my brother mfc. It would only do this during color scanning. b&w scanning was just fine. The tech support put me through resetting the reference point of the scanner through a series of button pressing and closing and opening the paper feeder. I kept gettting the same lousy results. Then they determined that the scanner module needs replacing and I needed to take to the nearest service center.
Dec 23, 2008 | Brother MFC-8640D Printer
Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Jan 05, 2007 | Canon DR-9080C Path-Through Scanner
ScanSoft OmniPage Pro Office 12.0 for PC Logo
Top ScanSoft Computers & Internet Experts
vsri9
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
