Question about RCA CD Player/Clock Radio (RP5640)
RCA5640 CD/Clock Radio Problem
Just recently my radio will not hold the volume on the AM stations (the sound gets louder and then softer) however, the FM stations work fine. Any ideas?
  • 1114 Answers
SOURCE: Setting a Radio Station for Wake Up
You can download the manual from the link below: Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 30, 2007
  • 1114 Answers
SOURCE: 12:33 keeps flashing
Hi - You can download the manual from the link underlined in blue below:
moz-screenshot.jpgRCA RP5420
Posted on Jul 31, 2008
  • 2992 Answers
SOURCE: Need user manual for rp3765a
Here's a link to a site that claims to have the manual.
In order to download you need to register. It's free. I haven't used this site but I do download from a few other tech sites that require registration. It's never led to any problems (spam emails, etc.) but you should scan anything you download from any site for viruses just to be safe.
Posted on Dec 06, 2008
  • 10594 Answers
SOURCE: I have lost instructions
Please download required Instruction Manual from HERE.
Posted on Feb 03, 2009
Possible solution for some of the problems listed: Turn the clock upside down so that the label is readable in the upper left area. On the right side you will find a compartment which may have two "AA" batteries installed. These back up the setting when the clock is unplugged.
To reset the clock, you will have to BOTH remove the batteries AND unplug the AC power cord. Also, make sure the batteries are not dead.
Finally, although I cannot confirm this, there is an opening directly under the label (still looking at the bottom of the clock) which appears to be a "Reset" switch. A pointed object such as a ballpoint pen or toothpick will be needed to press this recessed button. Hope this helps. Mine is working just fine.
Posted on Mar 15, 2009
How do I change my cd clock radio to AM
probably doesnt have AM option. You have high quality CD sound and high quality FM sound, they don't let you have bad quality AM. Having said that it does.
Press the ALM OFF/SOURCE button to select the FM or AM mode.
Press the
/MIN button or
/HR button step by step to tune to the desired radio stations.
Press and hold the
/MIN button or
next radio station in the direction of the search. The search operation simply finds stations with
strong signals. Stations with weak reception can only be tuned in manually
Onn ONB14AV201 Product Manual Product Features View
Jul 09, 2017 | Audio Players & Recorders
Radio no longer has any volume: Resets suggested dont work. How to pull this sucker apart?
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Jun 03, 2015 | Boston Acoustics Horizon Solo Clock Radio
How do I change radio volume on the alarm?
This clock is supposed to have an automatically "increasing" volume feature (starts off low, gets louder over a minute or so).
If not sufficient, look on the top right side of the clock, there should be an up/down volume control. It is a black oval-shaped button with a picture of a sound speaker in the middle. Push it upward to increase volume and downward to decrease volume. Unfortunately, you have to have a flashlight or light on to see it because none of the controls are illuminated.
Dec 02, 2013 | Sharper Image Sound Soother White Noise...
Radio Randomly Gets Louder And Softer
your radio is bad. the valuim botton is bad. the best way to fix the problem is to replace the radio.
May 11, 2013 | 1993 Oldsmobile Cutlass Ciera
Set alarm clock
or follow instruction
  1. Press the SET button until WAKE 1 / WAKE 2 icon is blinking.
  2. Press REV or FWD to set the wake time. The time decrements or increments will follow by a faster rate when you press and hold either REV or FWD.
  3. After the WAKE time is set, press SET repeatedly until no icon is blinking.
  • The unit equips with GRADU- WAKE feature, the alarm tone volume will increase gradually to its maximum in about 30 to 45 seconds.
  • If you set the SLEEP function with low volume level before going to bed, we advise using WAKE mode to wake you up since its volume will automatically increase.
Waking by Selected Source: You may be woken up by WAKE, RADIO or CD.
  1. Select an AM or FM station.
  2. Set wake time (see above directions).
  3. Press WAKE 1 or WAKE 2 to select waking up by WAKE, RADIO or CD. Corresponding indicator will be shown next to the selected setting.
  4. Adjust the volume by turning VOL.
You can select your CD wake track by the following procedures:
  1. Make sure you have inserted a CD.
  2. While holding WAKE UP CD TRACK, press REV or FWD to select your desired CD wake up track.
Mar 18, 2011 | RCA RP4803 Clock Radio
How do I set the clock on my Pioneer DEH-P6200 cd receiver?
With the vehicle on, turn OFF the radio. Next, Press the Volume and hold the VOLUME knob. You should see LANGUAGE on the display. Scroll the VOLUME knob until you see CLOCK SET. Pres the VOLUME knob and the HOUR will start flashing. Scroll the VOLUME knob to set the hour then Press it to set the Minutes. When you're finished. Turn off the radio, then turn it back on. When the radio is in use, the Radio Station will scroll on the display, then the Artist information, then after a few seconds (20-30), the Clock will display.
Jan 14, 2011 | Pioneer DEH-P6200 CD Player
Manual stolen when car was vandalized, need to know how to set clock and radio stations in 1994 Ford Tempo please
setting stations on Fords are easy,put it on the station you want to program and push the channel button in and hold for about 2 seconds then it should flash,now the channel is for the clock,with the key on and radio turned off,press the clock button,then press the seek or scan forward or reverse to adjust the time,then hit the clock button again to make sure it sets.
Oct 22, 2009 | 1994 Ford Tempo
How do I change the radio station on the radio alarm
Here is the full manual
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
I have a problem with time display on my Bose CD/Clock Radio.
I found the answer on the Bose website in the manual for the radio. While the radio is on, hold down Alarm Setup and preset 1 at the same time. That will set it so the clock displays. If you do the same thing but hold down preset button 2, that will display the radio info all the time.
Nov 23, 2008 | Bose Wave Radio
50 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
