Question about Dell Inspiron 15 Laptop
How do i reboot my laptop - Dell Inspiron 15 Laptop
How do i reboot my computer
To reboot the desktop machine, kindly press the power on button for few seconds / small button(reset) below the power button to reboot the computer.
If its laptop follow the below steps
Determine what operating system it uses. Finding out what operating system your laptop uses will let you know what key combo (such as "Ctrl+Alt+Delete") can exit you from usage and trigger a reboot or shutdown.
Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up.
Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately.
Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually. A few seconds should do unless you have additional problems.
Oct 15, 2010 | Computers & Internet
When i turn the laptop on i get a screen that says enter HDD password
You would have setup the hard drive password to come up on every reboot of your laptop. If you do not remember then the only way to remove it would be take the laptop to an authorized service center.
Jun 30, 2010 | Dell Studio 1737 Laptop
The laptop won't reboot and stays on a black reboot screen
Registry problems, You would have to re-install windows most easiest and fastest way.
Try to have a clean Installation Hazard: Always remember to back up your data!
Mar 22, 2010 | Toshiba Satellite M45X-S331 Notebook
How doi reboot my laptop without the reboot disk?
Uncle, Why do you want to reboot the laptop? And what do you mean by reboot as reboot means that you restart the laptop. If you want to start in DOS command prompt then you can press F8 at bootup time and you will be given many options to choose from One of them is the Command Prompt. Select that and you will land up with a black screen and a C:\ prompt. If that is what you want.
Nov 14, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Cant reboot my laptop can someboby tell me how to do it with out
As a standard reboot? Click start, then turn off computer, then reboot.
If it doesn't work like that hit CTRL ALT DELETE all at the same time and then Click shut down at the top and then Restart as the option.
Oct 19, 2009 | HP Pavilion dv6000z Notebook
Reboot my hp laptop
Hold and press the power button down ( and dont let go ) for at least 10 seconds or untill laptop shuts down and you can reboot by powering it back up by pressing power again. If it still shows access denied after you rebooted then more than likely you need a password.
Jan 02, 2009 | HP Pavilion DV6405US Laptop
Rebooting
boot your laptop in safe mode, if it boots then restore it to some previous date where its working fine
Sep 17, 2008 | HP Compaq nx7010 Notebook
Reboot to get rid of virus
When it says to "Reboot" it means to restart the machine, shut it down and then turn it back on again.
Jul 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Cannot reboot
reboot means is to restart again your computer, if the laptop cannot reboot then maybe got and error to your system.
and if cannot be shutdown, just long press, the power button until it shutdown, donot dehydrate or discharge the laptop battery , may damage the battery.
If the computer system experience this maybe you have to reinstall the windows correct the current error.
may this help, melnavz
PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 18, 2008 | Acer Aspire 5050-3242 Notebook
Laptop reboots itself
when does it reboot? does the laptop attempt to load windows?
Aug 23, 2007 | Gateway SL1450-30165297 Notebook
Dell Inspiron 15 Laptop Logo
19 people viewed this question
Alun Cox
